Old 04-29-2004, 08:00 PM   #1
69K10 Tank
Installed electric fan, engine temp. question
Well I just got done installing a 16" electic fan that I got at my local junk yard. I also put a new temp sender in the block, since the PO didn't have one in it. I cant say how well it works, because I don't have anything to base it on. My question is, how hot does the temp guage read with the stock fan and shroud on a 350? Thanks guys.
Cry havoc and let slip the dogs of war
69 K-10, 350, sm465, T221, 33" BFG A/T, drums all around (soon to be discs)
69K10 Tank is offline   Reply With Quote
Old 04-29-2004, 08:04 PM   #2
Quagmire
A splendid one to behold
Quagmire's Avatar
mine has always ran right at 190 iirc
67 swb
02 wrx
Quagmire is offline   Reply With Quote
Old 04-29-2004, 08:54 PM   #3
Randy70C-10
Randy70C-10's Avatar
Between 180-190 is really good. Mine runs around 200 on a hot day and I don't even worry when it hits 210.
Randy70C-10 is offline   Reply With Quote
Old 04-30-2004, 01:25 AM   #4
dmec
dmec's Avatar
where between C and H is 180? just curious. i run a gauge with numbers.
dmec is offline   Reply With Quote
Old 04-30-2004, 01:49 AM   #5
2low72
my 350 with a flex fan and no shroud runs 190
2014 GMC Yukon XL (Wifey's)
2004 Chevy Silverado Crew Cab Z71
2low72 is offline   Reply With Quote
Old 04-30-2004, 03:34 AM   #6
canadianchevy72
350 with clutch fan runs 190 highway havent driven her in the city yet.
1972 Chevy C/10
350/200r4
canadianchevy72 is offline   Reply With Quote
Old 04-30-2004, 08:55 AM   #7
Randy70C-10
My guess is somewhere just past the middle, that's where they always seem to run when nothings wrong with the engine.
Old 04-30-2004, 09:16 AM   #8
jorgensensc
jorgensensc's Avatar
We have had this discussion before about these temp gauges. It seems the consensus is no one really knows. Some peoples gauges read straight up, some people's read just to the first line, and some people's read just past the middle. My suggestion is that you run the vehicle with the cap off and then put a thermometer in your water at the radiator cap when you are at operating temp. Or you could always borrow someones numbered gauges for an afternoon, wire it up and see what it does. Sorry if this isn't much help.
Shawn
Disclaimer: I am not liable for scalding that may occur while running the truck without a radiator cap.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 04-30-2004, 09:24 AM   #9
Randy70C-10
I'm going to put a numbered guage on my truck in addition to the original one, they don't take up too much space anyhow, plus I like to see what the engine is doing. The two most important gauges are the water temp and oil pressure.
