04-29-2004, 08:31 PM | #1 |
Saving 1 truck at a time!
Windshield Wipers Stop Straight Up!
Anyone know what is going on here? They work fine but stop at the salute position rather than continuing down to the cowl.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
04-29-2004, 08:42 PM | #2 |
wiper
Did you check your wiper trans is not 180 degrees out? it could be yoor switch too.
04-29-2004, 10:36 PM | #3 |
Almost done!
Most wipers have 3 power circuits, 1 for low speed, 2 for high speed and a 3rd for the park feature. If the wipers are stopping where they were when you turne the switch off, I would suspect the park circuit (wiring or in the motor its self). If they are parking in the wrong place, I would suspect the timing of the linkage. Good luck...
04-29-2004, 11:48 PM | #4 |
It's a catastrophic success.
The wiper motors are mounted on rubber mounts insolating them from the cab(ground) the switch completes the circuit by giving the motor ground, when you turn off the switch you remove the ground,but inside the moter mechenism it has an over ride untill it gets to the stop point then it looses its ground completly and stops the motor.
04-30-2004, 01:56 AM | #5 |
If the linkage is installed correctly, it could be the park ring in the motor has a break or crusty spot in it causing it to park in the wrong spot. In other words, the motor could be bad.
72 Cheyenne Super 4x4 SWB |
04-30-2004, 11:40 AM | #6 |
It stops in the same place every time...straight up. They are indexed properly since they sweep the windshield properly...just stop every time in the wrong spot...90 degrees out. They do continue to run until they get to that spot however. Maybe it is the motor indexing if it has four bolts since it is 90 degrees out of phase for the stop position. I will check that.
07-22-2016, 04:10 PM | #7 |
Re: Windshield Wipers Stop Straight Up!
What happened how did you fix it? I have the exact same problem with my 72 blazer.
07-22-2016, 05:27 PM | #8 |
never mind. Illogical idea!
07-22-2016, 05:39 PM | #9 |
This is the very rare optional high speed aerodynamic park mode (RPO O YEAH), very desirable when cruising over 200mph. DO NOT mess with this
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
07-22-2016, 06:04 PM | #10 |
Maybe not so illogical. Look at the direction the wipers move when you turn them on. Shut them off. Reposition them so that they are in a position down and when you turn them on they can move again.
07-22-2016, 06:40 PM | #11 |
When I turn them off they return to the 12 o'clock every time. They go through the cycle correct,all the way down to all the way up. The weird part is that when I turn them back on they first go down then continue on there cycle. I suspect if I just turned the wipers back down on there studs when I turn them back on wouldn't they just go down and smash some cowl?
07-22-2016, 06:49 PM | #12 |
they probably would. That is why at first I thought my suggestion was illogical. I would imagine that if you put them to the other side down position when off they would only go to 12 o'clock and then smash into the other side of the cowl. Obviously there is some mechanism that tells the motor when to shut off that is not in the correct place. If I change my shut off on my garage door the door would stop going up or down based on the switch.
07-23-2016, 06:52 PM | #13 |
My truck was like this. To fix it is pretty simple, you dont have to do anything in the cab.
You first need to remove the wiper arms. There is a little tab you bend up, then pull them straight up. Just google or search this site for pictures of it. After wipers are removed, you need to remove the cowl trim. There are screws that may be rusted so you need to spray them with lube, then two bolts on either side you have to open the doors to access. With the cowl removed, the wiper arms connect a lever in the middle. It is attached by a bolt and clip. Remove the bolt and clip, take the arms off, and you will see a little arm/lever that attaches to the actual wiper motor in the cab. Take off the little lever, turn it 180 degrees, and connect everything. Now the wiper blades will stop in the DOWN position. You may need to put wiper blades on and adjust where they stop 2 or 3 times before you put the cowl back on, but this is how you make them stop in the down/correct position. |
07-23-2016, 07:53 PM | #14 | |
