Old 04-29-2004, 11:24 PM   #1
75-K5
Bucket of Bolts
Lowering rear end an inch or so
I'd like to lower the rear on my shortbed just a little. I like the height in the front, but I also like a little bit of rake to my trucks. The rear is just too high, though. If I could lower it about an inch that would be great. I don't really feel comfortable taking a spring out of the pack, for fear it will be too weak. Is there a relatively easy way to lower it without doing a complete drop?
This is the project that never ends, yes it goes on and on my friend....
75-K5 is offline   Reply With Quote
Old 04-29-2004, 11:28 PM   #2
TIMSPEED
TIMSPEED's Avatar
Does it have a drop shackle on it yet? That'd be an easy way to get an inch or so...
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 04-30-2004, 03:28 AM   #3
75-K5
Bucket of Bolts
Honestly, I don't know, does anyone happen to have a pic of one for reference?
Old 04-30-2004, 08:14 AM   #4
Low87
been here longer than Liz
Low87's Avatar
A drop shackle looks identical to the stock shackle, just longer (the leaf springs are mounted higher up). Most drop shackles I've seen have 2 sets of holes, so you can drop it 1" or 2". Might check to see if yours has an extra set of holes. If it does, hopefully they're above the ones you are using now. Thay way, you can change the mounting location of the springs and have your 1".
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
