Old 04-30-2004, 01:45 AM   #1
67cst
i love summertime
67cst's Avatar
DAMN grant wheel install!
howdy partners...im in the middle of installing my woodgrain grant wheel on my van tilt in the 67, and im getting hung up on the horn plunger, it says to discard the old one so i did now the brass piece that makes contact isnt long enough it seems....and i need the white plastic bushing in there so it keeps it off the metal sleeve it slides in..so what gives? who here has done this before? i dont want to just slap the wheel on, it would be nice to have a horn too...also my install kit didnt have a spacer..it shows that as the first thing that slides onto the splined shaft...maybe the instructions are universal or something i dont know...but do i need that spacer to begin with and also how do i get my brass plunger to make contact with the piece below it? any pointers would be great, thanks guys
Derek
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 04-30-2004, 03:03 AM   #2
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
Awww man, I wish I could help, same wheel different column...I forgot you had that van tilt, cuz at first I was like
"damn mine was easy, took like 5 minutes, whats he talkin' bout?!?"
then I remembered van van van...good luck man, hope thats the last part to complete it
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 04-30-2004, 07:22 AM   #3
70c10
67-72 Addict!
70c10's Avatar
I wish I could figure that out. When I installed my Grant horn, it was killing my battery so I finally diconnected it. Last night my horn cap flew off when I hit a pot hole. Scared the hell out of me,lol. barn9 should be here shortly to share his thoughts on Grant,LOL.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-30-2004, 07:58 AM   #4
rage'nrat638
rage'nrat638's Avatar
you have to use that little spacer coller first..
then i had to use adifferent plastic horn adaptor the one that has the wire coming out....
so spacer ,plastic horn adaptor,spring,alum wheel mount w/splines, then the metal cone the the wheel mount's to, nut.,
it's a lot of fun compressing the spring and lining up the mark's and getting it set...
i boungt a alum, wheel that was much more user freindly..
than the painted models...
rage'nrat638 is offline   Reply With Quote
Old 04-30-2004, 09:07 AM   #5
67cst
i love summertime
67cst's Avatar
thanks rage....i think i have it figured now, anyone else have any input?
Old 04-30-2004, 11:40 AM   #6
70c10
67-72 Addict!
70c10's Avatar
Mark, that wheel looks slick!
Jim
Old 04-30-2004, 12:16 PM   #7
barn9
Half a bubble off!
barn9's Avatar
LOL! Jim (70c10) always forces me to say "Grant horn kits suck!".
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 04-30-2004, 01:28 PM   #8
cdowns
cdowns's Avatar
if there's anything i've learned in 40+years of foolin with cars it's GRANT SUCKS!!!!!!!!!!!!!!
Old 04-30-2004, 01:56 PM   #9
70c10
67-72 Addict!
70c10's Avatar
I knew LB wouldn't let me down!
Jim
Old 04-30-2004, 08:24 PM   #10
67cst
i love summertime
67cst's Avatar
FUK..i have to wait until next wednesday to get a new kit...all because they didnt give me a damn spacer...grrr this is a major piss off, i wanted to drive it out on the driveway and take a pic of it with my dads 73 shovelhead he just got today...ill post some pics tomorrow...the bike is just awesome...
Old 04-30-2004, 09:28 PM   #11
crazy longhorn
Fabricate till you "puke"
I have run several of those Grant wheels, & really havent had any issues on the horn.....the old style (originally superior), there were issues. You would hit a pot hole in the road, & the chrome button & spring would "fly out" , & your best girlfreind(at that time ) would have to hold the contact plate off the wheel , while you got under the hood & disconnected that damn horn! most of the problems that I have seen with a grant wheel install, have been due to a pinched wire (done that), or bad contacts one 30+ yr old parts. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-30-2004, 10:21 PM   #12
stringpickin
stringpickin's Avatar
Location: Northern Ca. at the base of the valley just entering the sierra foothills
It has been so long that I can't remember what the issue was with mine, But I had the same problem until I realized one day while trying to get the horn to work that I had something completely backwards. After I turned it around, it solved all my problems. But this was 7 years ago. so, all I can suggest is if there is anything that looks like it can be turned around but doesnt seem to make sense. try it.. Good luck..
1970 Chevy 4x4 pickup w/72 running gear. 2 1/2" custom spring lift. Brand New 383 stroker-360hp. by Smeding. Edelbrock EFI Fuel Injection. Rostra Cruise Control, 700r4 conversion. ARB Locker/373.
Disciple of our Father YHVH and the Lord Jesus Christ.
stringpickin is offline   Reply With Quote
Old 05-01-2004, 01:04 AM   #13
Martin64
Martin64's Avatar
I had that problem with my last steering wheel. When I put the new one in this truck I junked all the horn wiring hook ups and put it on it's own button under the dash and put a slightly harder crimp (not noticeable) on the horn cap so it won't be as likely to fly off. I also taped the spring to the cap so it's alot easier to put on without fighting the spring and cap at the same time.
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 05-03-2004, 01:49 PM   #14
dtlilly
dtlilly's Avatar
I've got a Grant on my truck...and don't have a horn either
dtlilly is offline   Reply With Quote
