04-30-2004, 01:35 PM | #1 |
It followed me home?
more backspacing ?'s
This may sound dumb but it seams like different people give me a different answer. Fitment for backspacing stays the same regardless of the diameter of the rim right? So if I go with 4.5" backspacing on a 17" rim I should be ok right? thanks.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 04-30-2004 at 01:52 PM. |
04-30-2004, 01:56 PM | #2 |
Signals in the bumper.
Correct, nothing to do with diameter. However, I am sure you thought of this, 4" backspacing on a 8" wide rim will fit different then 4" backspacing on a 9" wide rim.
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
04-30-2004, 02:02 PM | #3 |
yeah I guess i should have mentioned that I would be running a 9 in rim.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
04-30-2004, 02:10 PM | #4 |
On my 17x9½, I'm running 5½" of BS on all of em'. If you run a 9" rim, I'd run 5" of backspacing. If you have a lift and you want the tires to be more flush with the fenders, you MIGHT even try 4.75" to 4½" to push the rims out more.
04-30-2004, 02:12 PM | #5 | |
