Old 04-30-2004, 08:58 PM   #1
kickinasphalt
kickinasphalt's Avatar
Hood is higher near the cowl...spring problem???
On my new 71 K-10, the hood sits higher in the back near the cowl. Its the same way across the width of the hood. Is this just the springs being old or something?
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73
1972 C-10 Longbox,350/350
1998 Pontiac Grand Prix GTP
FOR SALE: 1971 K-10 Longbox,350/SM465/NP205
kickinasphalt is offline   Reply With Quote
Old 04-30-2004, 09:54 PM   #2
shortymac83
hmm...
shortymac83's Avatar
it might be out of adjustment. Mine is misadjusted on the driver's side, so that it stays up at the cowl all the time. you push down on it, and it closes a bit more, but it hits the cowl with about 1/2" to spare.
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 04-30-2004, 09:55 PM   #3
Randy70C-10
Randy70C-10's Avatar
Loosen all the hinge bolts where the hood hinge bolts to the fender, have a buddy lift up on the hood while you tighten them back down. This works about 75% of the time. If it doesn't work then you need new hinges.
Randy70C-10 is offline   Reply With Quote
Old 04-30-2004, 11:25 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
While Randy's advise should do the trick, the normal problem is worn springs and/or hinges.
Old 05-01-2004, 02:09 AM   #5
rickspickuppart
It can't be a worn out spring if it is high in the back, for the springs to be worn out they would have to stretch out of shape and then they would fall off of the hinge in the open position (since they are only extended when the hood is closed). IMO there are only 2 things that can do it
1) hinges out of adjustment
2) worn out hinges (around the rivet locations)
Shawn
rickspickuppart is offline   Reply With Quote
Old 05-01-2004, 03:01 AM   #6
shortymac83
hmm...
wait a sec...aren't the springs extended when the hood is closed?
Old 05-01-2004, 07:07 AM   #7
supercheyenne
No. The best way to remove the springs is to put big nails in between the coils and lower the hood. The springs with then simply "fall" off because they can't compact with the hood.
That's the easy way to remember for me at least.
supercheyenne is offline   Reply With Quote
Old 05-01-2004, 08:35 AM   #8
Huck
Huck's Avatar
Reread what Randy said and do it. Most times and I mean most times, the hinges can be old, crappy and a wee bit worn and you can still adjust them to bring down the rear of your hood to align with your cowl. the trick is to put a little extra upward pressure when you have all the hinge to fender bolts loose and to tighten them before you release this extra upward pressure on the front of the hood. Just be careful when you do this that the front to rear alignment of the hood doesn't change and pinch paint off the hood to cowl edges. Trust me, it works!!!!!!!!!!!!!!!!!!!!!!!1 Be sure to follow on this post if it works so we can refer back --for others with the same problem.
Huck is offline   Reply With Quote
Old 05-01-2004, 11:14 AM   #9
tom hand
CCRider
tom hand's Avatar
Hmmm...mine are
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 05-01-2004, 11:33 AM   #10
highboy_04
highboy_04's Avatar
yeah i think the springs are extended when the hood is closed.
'67 c10 350/th350
highboy_04 is offline   Reply With Quote
Old 05-01-2004, 01:38 PM   #11
rickspickuppart
you guys are right about the hood position after I shut the down the computer last night and went to bed I also realized I was wrong. (I edited the previous post to show correct info)
But anyways it isn't the springs
Shawn
Old 05-01-2004, 02:18 PM   #12
shortymac83
hmm...
the reason the nail trick works is because the springs are stretched when the hood closes and roll off the nails.
Old 05-01-2004, 11:27 PM   #13
supercheyenne
I'm going to have to check mine since 3 or more guys have claimed it so.
I could have sworn the springs are extended (out, longest, whatever) when the hood is up. But it wouldn't be the first time I was wrong.
Old 05-03-2004, 07:33 AM   #14
stingray72
Red Headed Step Child
stingray72's Avatar
These suggestions here worked like a charm. Took about 15 minutes to get it adjust exactly right but it was easy. Just loosen the bolts and push up on the hood when open and viola problem fixed. Saved me some money for hinges.
Oh.. and I looked and I believe the hinges are extended when the hood is closed.
"Dinner, the perfect break between work and drunk"
-Homer Simpson
stingray72 is offline   Reply With Quote
Old 05-03-2004, 09:22 AM   #15
spencra
This, is my BOOMSTICK!
spencra's Avatar
Yeah, I have the same issue with both of my 67's. I just chalk it up to alignment since I'm almost 100% sure that those hoods have been taken off and put back on several (hundred) times over the last 37 years.
Larry
Got rid of my projects for now.
1980 Jeep CJ7
1998 Nissan Sentra (my car)
2001 Toyota Sienna (wife's, of course)
spencra is offline   Reply With Quote
Old 05-03-2004, 02:45 PM   #16
67chevemall
67chevemall's Avatar
Just keep adjusting it!
It took me about 5 hours to get mine right!
So I didn't have to push the corner down every time I shut the thing!
I had a body pro around the corner help me out for a little something!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 05-27-2004, 01:25 PM   #17
KP1972
KP1972's Avatar
I just took my hood off to paint the underside, removed and cleaned the hinges, now I have the same problem. The hood is high (less than 1/2 ") at the cowl. What is teh quick fix??
1972 Chevy Custom/10
www.PictureTrail.com/KP1972
Metroplex Muscle Car Club
www.PictureTrail.com/DreamCarArt
KP1972 is offline   Reply With Quote
