Please Help! i'm desperate
Hi there folks, I recently parked my truck for a few months, I was working out of town for 3 months....I come back and I started it up and it idled beautifully one night, and the next day....I would start it up and it would idle for like a minute maybe less, and it would just die.....I don't know what the problem is, It will only stay on for about 10 seconds sometimes, then it just dies, I tried a different carburetor off of my brother-in-laws truck and it did the same thing, I don't know what the deal was, but I remember when I was driving it before I parked it, sometimes it would bog down when I pressed the gas all the way...anyways Please Help, thanks lots!
Did you put new gas in?
Fabricate till you "puke"
Or possibly a weak fuel pump.....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Almost done!
It sounds to me like you have developed a major vacuum leak. With the engine running, take a pair of needle nose pliers and pinch off all vacuum lines. If the idle improves, you have found your problem. Don't forget the brake booster and the PCV hoses.
The 1970 SWB Project Removed 6cyl manual trans, manual everything V8-350 Auto/PS/PDB Blazer Fuel Tank Behind the Marker Light Fuel Fill |
#5 | |
#6 | |
you could have a clogged strainer on the fuel pickup in the gas tank
Secondary ignition problem? plugs, wires, cap, rotor, coil, points, condensor.
Nothing clever
um I dont know that much about all this stuff, but I would start with the fuel filter.
Got "the Midas Touch!" |
Don't know if it is your problem or not, but this worked for us recently with a friend's sedan delivery. Has similar symptoms, finally disconnected the fuel line after the tank and blew air in the tank. Heard a little thunk and it's been running fine ever since.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
HAD SIMILAR PROBLEM W AN OLDER F**D. After spending several hundred dollars replacing fuel pumps, carbs, coils, plugs, wires, i rechecked the condenser (a $2 part) and that was it. I replaced nearly everthing I could think of but somehow overlooked it. Try the cheaper stuff FIRST... Good Luck..
Oh Yeah,I forgot to tell you, Mine did the exact same thing. cold started good but after about three minutes it would die. Let it cool off and it started just fine and would do the same thing again. The condenser can look fine outside (still shiny) but be bad. My truck had also been parked for a while previous to this problem. Thought I was gonna go nuts...No more F**rds!!!!!
#13 |
My other Love
same problem starting my 77 this year, had an airlock in the fuel line, after a while of dumping gas down the carb, it eventually ran fine
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
