Old 05-01-2004, 12:35 PM   #1
slammd72
slammd72's Avatar
3/4 ton to 1/2 ton
I was wondering if i could make the front of my 77 3/4 ton into a 1/2 ton using the parts off of my 72?
88 shortbed crewcab
currently getting a sfbd 4 1/4"
slammd72 is offline   Reply With Quote
Old 05-01-2004, 06:00 PM   #2
Faster_than_you
hmmm...not to sure dude, check and see who had gone from a 72 and convereted it to the 73-87. possibly the same concept.
~Christopher L. Orr
71 c20, 454- Stolen While Deployed. dynoed at 550 ft lbs, 425 hp at 3000 rpm (mustang dyno). TH400 3500 stall.... etc, etc.
Faster_than_you is offline   Reply With Quote
Old 05-02-2004, 12:18 PM   #3
crazy longhorn
Fabricate till you "puke"
Yes , you can swap it. you should be able to bolt the complete eng cradle under the truck with only a couple holes to adjust(egg out). You can also swap the lower a arms, with balljoints,the spindles, & upper balljoints onto the exsisting crossmember. the outer tierod ends will also be different(probably easier to use the center link,tierods, ect from the 72). good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-02-2004, 01:26 PM   #4
slammd72
slammd72's Avatar
cool........when you say eng cradle is suppose you are talking about the k-member, right?
88 shortbed crewcab
Old 05-02-2004, 01:39 PM   #5
crazy longhorn
Yup, thats it in the pic....good luck,crazyL
Old 05-02-2004, 02:17 PM   #6
slammd72
slammd72's Avatar
there are 7 bolts on each side of the member.....which ones have to be "persuaded" b/c i would rather just put my notched member on the 3/4 ton and make it a 1/2 ton and slam it at the same time
88 shortbed crewcab
Old 05-02-2004, 04:22 PM   #7
crazy longhorn
I have a 77 crossmember to notch & swap into my 69.....but havent done it yet. I have been told that 1 bolt on ea side of the frame is the offender(not sure which one, but the bottom 3 on ea side line up. when you set it up, post your findings to give this old man a "heads up". good luck,crazyL
