wiring geniuses painless ???
i have been installing a painless wiring harness in my 72 4x4 c-20. all is goin well then today i am trying to hook up the headlights and turnsignals/marker lights. the factory has four wires per side to hook the parking/turn signal light up and the marker light. they conect into just two wires a blue and brown. in the painless kit there is a blue( for turn signal) one a brown(for parking lamp) one and a two color brown/whit one (for side marker) how the heck do i hook all this up. i was gonna connect the parking light one and the turn signal to the matching colors on the factory part, but what of the other wire for side markers? Thanks for any help
Ryan |
ask randy70c10, he just installed a painless kit. he said something about some wires needing to be in different places. he also posted his every move.
~Christopher L. Orr 71 c20, 454- Stolen While Deployed. dynoed at 550 ft lbs, 425 hp at 3000 rpm (mustang dyno). TH400 3500 stall.... etc, etc. |
I installed a painless in my 72 a month ago.
The park/turn signal lights do go on as per factory , with the brown and blue matching up. The markers - use the brown and white to power the marker light, and you supply your own black ground wire for the other wire coming off the marker light. Ground it to a body or chassis bolt. Headlights are also easy. Plug the headlight harness pigtail in, and then run the painless wiring up to the pigtail, and connect with the supplied butt connectors. The kit is awesome.
72 C10 Cheyenne Super Full trim Factory tach dash A/C dash Factory tilt 350 / 350 power train - with Edelbrock components. |
#4 | |
Also, for any of you guys running an electric fan, you have to get the fan relay kit, part number 30101. It's also a very easy install. |
thanks both of you for the help, i should get the front harness buttoned up today.
Ryan |
