Old 05-01-2004, 12:59 PM   #1
moodyholler
moodyholler's Avatar
Rear Axle Problems
I need help with my rear axle. 3:07 posi from a 72 4x4 blazer. It is very noisy and has .120" slop at the axle flange. I also wish to change it to 3:73's. Any special tools needed to make this change? Where can I find the procedure? My factory manual does not have this info. I have depth guages and dial indicators and am mechanically inclined. Whose gears do you guys like? Can I change the carrier bearings and pinion bearings out if gears are ok? thanks,moodyholler
1998 WRANGLER I-6 auto
1972 LWB FLEETSIDE
1968 GMC SWB STEPSIDE
1994 C-1500 SWB 4.3 5 SPD
moodyholler is offline   Reply With Quote
Old 05-04-2004, 12:52 AM   #2
skid
If you have that much slop, everything is probably worn out. The axle tips have worn off causing a slurry of abrasive particles that have worn everything (only a few thou of the axle tips are hardened). I'd replace everything....I'm in the same boat. I put in new axles and still have too much slop. I'm going to do a gear change as well eventually. Make sure you put a magnetic plug in your diff!
Toys:
72 K5 Blazer
74 Vette
skid is offline   Reply With Quote
