Old 05-01-2004, 06:07 PM   #1
1985K10
1985K10's Avatar
Did some body work today!
Finally got around to fixin my rust and big dent! Here's some pics of what my dad did.
Anthony
07 Tahoe LT
70 Chevelle 450HP 383-TH400
77 GMC Royal Sierra~Resto in progress~
1985K10 is offline   Reply With Quote
Old 05-01-2004, 06:08 PM   #2
1985K10
1985K10's Avatar
2
Anthony
07 Tahoe LT
Old 05-01-2004, 06:08 PM   #3
1985K10
1985K10's Avatar
3
Anthony
07 Tahoe LT
Old 05-01-2004, 10:26 PM   #4
soleeagle
soleeagle's Avatar
Looks good. Did you weld metal back into the holes or what did you do?
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
Old 05-02-2004, 04:04 AM   #5
TwinTurbo
TwinTurbo's Avatar
Yea, you forgot to take pics of the biggest pain, welding in and shaping the patch panels
TwinTurbo is offline   Reply With Quote
Old 05-02-2004, 07:17 AM   #6
1985K10
1985K10's Avatar
The driver's side had a huge dent in it(below), we pushed that out and filled in the low spots. The pass side was patched with metal, hopefully good welds too. Last time it was brazed, this time MIG welded.
Heres the dent before...it was worse than it looks...
Anthony
07 Tahoe LT
Old 05-02-2004, 08:30 AM   #7
TwinTurbo
TwinTurbo's Avatar
There's a neat trick to pulling a dent out, tac weld a lot of nails onto the body and start pulling out from the outside in, when done grind off the nails. There's a special dent puller gun (which welds itself to the body and releases by twisting) but the nail trick works great too.
Old 05-02-2004, 08:40 AM   #8
RockHQ
ROCKET POWER!
RockHQ's Avatar
The dent puller is f**king awesome, i wish i'd have the money to buy one for myself. Gotta make do with what i've got at work. Anyway, if you use the nail trick or the dent puller you'd really want to solder the area afterwards (bot sides) before applying any surface coat.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 05-02-2004, 08:43 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
That all looks good. I hope y'all sanded most of that red spot putty off though. Since it's not a catalizyed filler, it can cause nightmares with modern paints.
I just had my bed and one of my doors repainted because you could see the shadows of where they had used red spot putty...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-02-2004, 09:39 AM   #10
TwinTurbo
TwinTurbo's Avatar
Originally posted by RockHQ
Anyway, if you use the nail trick or the dent puller you'd really want to solder the area afterwards (bot sides) before applying any surface coat. [/B]
Dom you mean soldering lead onto it and grinding it down? That's old style work but still the best (too bad lead fumes are no fun)
Oh it's called lead loading if I remember correctly
Old 05-02-2004, 03:05 PM   #11
1985K10
1985K10's Avatar
The "Red Lead" still needs to be sanded off, and we did use it before and there were no shadows. Just got home from a swap meet, got some new wheels!!!!
Anthony
07 Tahoe LT
