Old 05-01-2004, 07:00 PM   #1
ChevyDude
Engine Progress...yes she has Red nuts!
Here is the 350 engine that is going in my 71 Torch Red SWB. It's still missing the red fan and a few other items. I have been having fun painting up all the goodies as I am patiently waiting for my truck to finished. All the blueish-silver is Rustolium Hammered silver, the nuts are torch red and the block is Chevy orange. Everything that was black in the engine bay is now Hammered Silver and all the nuts are Torch Red. I'm thinking it's going to be sweet siting in a Torch Red truck with Chrome inner fender wells! Thanks for looking!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 05-01-2004, 07:06 PM   #2
ChevyDude
My garage is still a mess......2:
Alex
Old 05-01-2004, 07:09 PM   #3
ChevyDude
3:
Alex
Old 05-01-2004, 07:11 PM   #4
ChevyDude
Last one:
Alex
Old 05-01-2004, 07:21 PM   #5
Faster_than_you
That looks BadA**!!
~Christopher L. Orr
71 c20, 454- Stolen While Deployed. dynoed at 550 ft lbs, 425 hp at 3000 rpm (mustang dyno). TH400 3500 stall.... etc, etc.
Faster_than_you is offline   Reply With Quote
Old 05-01-2004, 09:16 PM   #6
dwaite72lnghrn
Looks good. The only thing I can say is it looks like you used the front gasket on the manifold. I could never get it to seal with that gasket, Too thick for the side gaskets. Check for water leaks before you run it hard. I finally used the felpro side gaskets and RTV on the front and rear. Just a thought.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 05-02-2004, 10:22 AM   #7
MACKL
Almost done!
MACKL's Avatar
I learned the hard way not to use the front and rear intake gaskets. Not looking forward to repairing. I think the contrast of the flaming nuts looks good. I'm sure you will be the only one with them!
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline   Reply With Quote
Old 05-02-2004, 11:12 AM   #8
Jimmy72custom
Jimmy72custom's Avatar
Good job, great pictures they are real motivating.
Jimmy72custom is offline   Reply With Quote
Old 05-02-2004, 12:15 PM   #9
ChevyDude
Thanks for the nice comments! You guys do have me thinking maybe I should remove the intake and get rid of the front and rear rubber gaskets. These are not the type that have the center rubber bead. They are the Victor brand from Napa that are flat. I asked the parts guy if they have reports of the front and rear seals leaking and he told me "No". Should I remove them before I put this engine back in the truck?
Alex
Old 05-03-2004, 05:29 AM   #10
dwaite72lnghrn
I'm not saying you will have a problem I am saying I had problems with Felpro and Mr. Gasket that was listed for the performer intake. The front and rear rubber type gasket is to thick for the sides and you can't seal the side water jackets because of this. When I first did it I thought I would follow the directions (first mistake going against the male grain). fill oil, fill water/antifreeze get to the top od rad and I see green coming out the manifold, WTF? empty water empty oil, take a road trip for gaskets they only had Mr. gasket for intake. Get back read direction (what am I crazy) put everything on fill oil fill water only intake leak same place driverside head-manifold. Tear it down take a straight edge to the manifold and head both straight! Head back out for another gasket NONE anywhere had to order them, When they come in screw the direction RTV front and back side gasket another dap RTV on the joint where it meets front and back throw it together wait an hour fill it fire it up and good to go.
So when you go to fill it pull the oil plug fill the RAD with water and watch for water top and bottom. after abit plug it put in oil and then fire it up. JMHO
2009 HHR aqua blue
Dave & Jeanne
Old 05-03-2004, 07:35 AM   #11
Bowtiefreak
Bowtiefreak's Avatar
Can't see pics
Is there just a board problem right now or do I need to reset something on my computer?
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 05-03-2004, 08:14 AM   #12
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Originally Posted by Josh
I Upgraded the board to the latest version, it should have More features and run smoother. I did lose all attachments posted after April 8th though. My database and backup both became corrupt so I had to revert to an older backup for attachments... All attachments posted before April 8th are still intact. No posts were lost to my knowledge.
I saw this post this morning.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 05-03-2004, 08:22 AM   #13
biglou55
Wink
The same with me can,t see pics
Certifiably crazy person
biglou55 is offline   Reply With Quote
