05-02-2004, 02:02 PM | #1 |
305 - 350 swap
I’m thinking about buying a 82 Chevy 2wd short wide but it has a 305 in it. I live in California so I have smog to think about. My question is, will the existing smog junk bolt up to a 350 (if so, what years) or will i need to find a donor truck that still has all of the OG smog stuff on a 350?
05-02-2004, 03:15 PM | #2 |
Everything from the 305, should bolt right up to the 350.
All of the externals should be the same.
Chris '92 ext. cab s/b 4.3L "Sparky" '04 crew cab 2500 4x4 6.0L |
05-02-2004, 04:25 PM | #3 |
"All of the externals should be the same"...for all years? or do I need a 350 out of an 82? thanks for the info
05-02-2004, 05:36 PM | #4 |
should be pretty much all years only problem you'll run into would be the intakes and valve covers on 87+ engines, and oil pan/flywheel/flexplate differences on 86+ engines.
