Old 05-02-2004, 03:06 PM   #1
Newt408
Got outrun by a F@#%
Not just any F@#% a 1 ton 4 door 4x4 diesel. Beat me by 6 tenths with 3 passengers. I was deffinately impressed. He ran his best time against me(just my luck) a 14.32 @94mph. He sure did embarrass my lil hot rod. : I guess his daddy has alot more money than I do.
The way of a fool is right in his own eyes:but he that hearkeneth unto council is wise. Proverbs 12:15
Newt408 is offline   Reply With Quote
Old 05-02-2004, 03:19 PM   #2
RockHQ
ROCKET POWER!
RockHQ's Avatar
What've you got to match him with?
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 05-02-2004, 03:24 PM   #3
zzChevy
BANNED
Re: Got outrun by a F@#%
3 passengers? What kinda strip was this?
zzChevy is offline   Reply With Quote
Old 05-02-2004, 03:35 PM   #4
Newt408
Just pretty much a fun day at the track. Pretty lax on the rules.
Old 05-02-2004, 03:44 PM   #5
Newt408
Mine's a 84 c10
sb 400
vortec heads
9.25 compression
comp xe 268 cam
edelbrock rpm intake
holley 670 carb
1 5/8 headers
40 series flowmasters w-2 1/2 pipe
k&n filter
recurved dist
2004r trans w/2200 stall
3.70 posi rearend
295/50 street tires
holley mech fuel pump
The best i've gotten out of her is 14.67 @91 and that was with the stock fuel pump and distributor with the advance stuck. Got the dist rebilt and recurved added the holley fuel pump and put a larger k&n filter on it and it run slower than last year. My best time last night was 14.88@90. On my last run I guess I lost fuel pressure about 300'from the finish line cuz she just fell on her face and i got outrun by a friggin volkswagon.
Old 05-02-2004, 05:23 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
You better not come to Houston if getting spanked by Ford's bother you. There are quit a few around here that will hand you your @ss in a hand basket. This bad boy runs 12.33's....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-02-2004, 05:34 PM   #7
1FaastC10
1FaastC10's Avatar
you compression is too low, that'd be a good start at getting some more power out of it. should be somewhere in the neighborhood of 9.7:1
1FaastC10 is offline   Reply With Quote
Old 05-03-2004, 02:22 AM   #8
southernmutt33
Location: utard land, known to the rest of the world as utah
a couple of yrs ago i had a toyota mr2 that was fast off the line an all the way through the top end at 140,,i got whupped by a f350 deisel 4x4 crewcab off the line..i could not believe the way he took off at the stoplight..he had me by a truck length until about 30 mph then i got even..... gosh i miss little street legal go cart......
if it aint got 4 wheels an a motor,its now worth talkin about......
if ya cant afford to buy it, then be hillbilly enough to build it, it's cheaper to build it anyway.....
be a man, stand up to your women an tell them your the boss, an if she dont like that, then ask her if she needs help around the house...
http://public.fotki.com/southernmutt33/
84 GMC 454, 3/4 soon to be a dually with one ton suspension.
60 1/2, lwb stepside..for sale
98 taurus, ugliest body stlye ford ever built, but dependable family car.
73 vistaliner, cab over, newest toy, reason for turnin 3/4 into 1 ton
southernmutt33 is offline   Reply With Quote
Old 05-03-2004, 08:17 AM   #9
gldevall
gldevall's Avatar
What kind of lights are you cutting? That time seems to slow for what you've got.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 05-03-2004, 09:47 PM   #10
Newt408
Well, against him not too good. Got a .709. He cut a .566. Anyways my next run was alot better except I lost fuel pressure about 300' from the finish line. I dont get it. When I was just running a stock fuel pump I didnt seem to have this problem but when I run a HP fuel pump I have this problem. Am I supposed to vent the return line since it is not being used with the HP fuel pump?
Old 05-03-2004, 09:50 PM   #11
Newt408
I wanted to run more like 10:1 but my machinist talked me lower so I could run regular unlead. No gripes about the compression Its around 175psi cranking.
Old 05-04-2004, 08:40 AM   #12
gldevall
gldevall's Avatar
I think the compression is ok. I'm running a 8.5:1 with stock iron, Hecho in Mexico heads and running 14.5's. What is the elevation over there? Are you spinning much off the line?
Old 05-04-2004, 09:24 AM   #13
Grim Reaper
How about a Diesel F350 Crew 4x4 running 11.42.
http://timber.arxys.net/albums/2-27-04/F350Run.wmv
If I had to guess I would say that truck is making about 1,100 HP. You just don't throw a 7,100 lb truck down the track at 118 mph without some really big numbers.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 05-04-2004, 08:56 PM   #14
Newt408
Aint really sure about elevation but I know I cant really get on the gas til halfway to second gear.
