Old 05-02-2004, 04:08 PM   #1
Ironhorse
Ironhorse's Avatar
Door Latch Broke ?
Got the truck out today and while opening the driver's door from inside the cab I heard a click and the inside door handle would not spring return to the neutral postion. Pulled the door panel off and can not see anything dis-connected. No springs or parts laying in the bottom of the door. Door handle still works but have to manually return it to position. Is the problem internal within the door latch, meaning I need to find a new one? Door still closes tight.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 05-03-2004, 07:57 AM   #2
vtblazer
vtblazer's Avatar
Door Parts
If you determine you need a door part and need something internal. I'm currently disassembling a set of doors right now, I may have it.
vtblazer is offline   Reply With Quote
Old 05-03-2004, 07:04 PM   #3
JimKshortstep4x4
Smile
The spring on the door control, (the part that the handle attaches to) has broken. They are available new or you can get a good used one as long as the spring is good. the springs are prone to break, from what I have seen.
67-71 will interchange, 72 is by itself as the stem is longer.
jim
Old 05-03-2004, 11:10 PM   #4
junkyardjohn
junkyardjohn's Avatar
jim
G.M. USED THE SAME DOOR LOCK MECHANISMS AS OUR TRUCKS IN FULLSIZE VANS UP UNTILL THE LATE 80s JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 05-04-2004, 08:52 AM   #5
Doug M
I had the same problem until my 75 year old yankee thrift mechanic dad fixed it. He said it was a common problem "back then" and they didnt want to go through the hassel of replacing the latch. He simply attached a long throttle return spring on the back of the handle rod, pulled the spring back to create tension and attached it as far back as possible to the cut out opening. All that was needed was a 50cent spring and removing door panel. Mine now works like a charm.
1954 GMC 150 (for sale)
1970 GMC 1500
2004 Road King
Doug M is offline   Reply With Quote
Old 05-04-2004, 11:27 AM   #6
COBALT
COBALT's Avatar
My driver's side door handle mechanism broke the other day when I went to open it. I pushed the button, and a cascade of parts fell inside the door.
After thinking I may pull a used one off a junker I decided to get a set of new ones from LMC just to see what the quality was like. I'm actually pretty happy with them. They look better than the originals.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 05-04-2004, 12:48 PM   #7
barn9
Half a bubble off!
barn9's Avatar
Lightbulb
Gary (Ironhorse), I just put new outside handles on my truck, and have the old ones in the garage. If you need a part, you are welcome to it, give me a call or an email, LB.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
