Old 05-03-2004, 03:00 AM   #1
bigmikey
My one headlight is brighter than the other, can someone help me????
I noticed that on my 69 chevy truck, that the one headlight is brighter than the other one. I asked someone about it and they said it could be the ground. So I fixed the ground wire, and its still the same. Could the bulb be bad?, or is there another possibility?, thanks in advance..
bigmikey is offline   Reply With Quote
Old 05-03-2004, 05:30 AM   #2
jimfulco
See if the bright one is a halogen bulb.
jimfulco is offline   Reply With Quote
Old 05-03-2004, 06:14 AM   #3
dmurphy68
check your grounds i had one do that and my groun wire was holding on buy a couple of threads
The very atmosphere of firearms everywhere restrains evil interference. When firearms go, all goes, we need them every hour.
- George Washington
No free man shall be debarred the use of arms
- Thomas Jefferson
Later Darren
http://www.myspace.com/dmurphy68
dmurphy68 is offline   Reply With Quote
Old 05-03-2004, 08:48 AM   #4
MACKL
Almost done!
MACKL's Avatar
I agree, sounds like another ground problem.
MACKL is offline   Reply With Quote
Old 05-03-2004, 09:33 AM   #5
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
If its a considerable difference then check your grounds, if its a slight,check the maker of the bulbs, one may be halogen and one not.
sneakysnake is offline   Reply With Quote
Old 05-03-2004, 10:03 AM   #6
6869704X4
Did you clean the contacts on the plug? I use dielectric grease to keep them clean afterwards.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 05-03-2004, 10:11 AM   #7
pickup6772
pickup6772's Avatar
Talking
I AGREE WITH THE GROUND, AND THE POSSIBILITY OF TWO DIFFERENT HEADLIGHTS. DID YOU REPLACE ONE RECENTLY? THE OLDER ONE CAN/WILL BE A LITTLE DIMMER THAN THE NEW ONE. IT'S BEST TO REPLACE BOTH AT THE SAME TIME.
MIKE
'67 C/10 2WD LWB
'89 MERCURY GRAND MARQUIS LS
COUNTRY TILL THE DAY I DIE
pickup6772 is offline   Reply With Quote
Old 05-03-2004, 11:19 AM   #8
barn9
Half a bubble off!
barn9's Avatar
Wink
Headlight fluid may be low on that side. Sorry, couldn't resisit, LOL! It was a chance to make a post on this new board format to see how it works.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 05-03-2004, 07:31 PM   #9
racedvl
racedvl's Avatar
I'm also gonna jump on the ground band wagon.
racedvl is offline   Reply With Quote
Old 05-03-2004, 09:20 PM   #10
walker
walker's Avatar
If it is not the grounds I would suggest replacing the filiment bearings (or are they bushings??) You may try getting aa headlight rebuild kit from napa (part #1287-848), or if you really get into a bind I do have a matched pair of bulbs I could let go for about a hundred bucks.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
