05-03-2004, 09:11 AM | #1 |
MY TRUCK IS FOR SALE!!
Please check this out
Alright all,
Today is going to be the first time I have every dropped a transmission and put another one back in.... Got any tips or tricks for me? Anything will help, I think I pretty much know, but I wouldnt like any surprises right in the middle of it or while Im under the truck...!!! Thanks yall!!
1979 Chevy LWB 350ci / 700R4 Edelbrock under the hood F O R S A L E OR T R A D E |
05-03-2004, 09:16 AM | #2 |
Take off the linkage first. Use a jack! and watch your fingers. it's heavy.
Good luck |
05-03-2004, 09:17 AM | #3 |
thanks for the input.....
Here is what I have done so far... disconnected everything that is attached to the tranny with the exception of the driveshaft and the engine block....
05-03-2004, 10:12 AM | #4 |
Is there a trick on getting the driveshaft out of the transmission?
I disconnected it from the rear defferiential but I cant seem to get it out of the tranny
05-03-2004, 10:13 AM | #5 |
You get what you pay for
Don't forget to support the engine. Put a block of wood under the oil pan to keep from denting it in.
Mike 1985 Chevy C-10 |
05-03-2004, 10:14 AM | #6 |
I didnt know you had to support the engine
05-03-2004, 10:18 AM | #7 |
you have to pull it straight back about 1/2 to 1 inch before you can drop it down.
05-03-2004, 10:19 AM | #8 |
alright I'll check it out
05-03-2004, 10:42 AM | #9 | |
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
05-03-2004, 12:05 PM | #10 |
alright yall, I am a little nervous
I have all the bolts removed from the flywheel and the engine block.... I have the tranny supported with a jack and a piece of wood... I suppose that next I am going to remove the cross-member, right? And the I guess pull the tranny towards the rear of the truck and it should drop right?
05-03-2004, 01:10 PM | #11 |
come on fella,
at least tell me if thats the right way to do it I am down to one (stubbern @$$) bolt left on the cross-member if and when I get that last bolt out thats it right? just pull the tranny towards the back and watch out right?
05-03-2004, 02:14 PM | #12 |
Slots go on anything!
Sounds like that should do it. Make sure you have the trans cooler lines loose, or that will really hold you up.
1974 Jimmy- 5.3/4L80e/NP241 |
05-03-2004, 03:03 PM | #13 |
Nothing to be nervous about. Just be aware all the weight is on the front because of the torque converter. The converter will probably fall off if not careful.
05-04-2004, 03:57 AM | #14 |
Be sure the converter is unbolted from the flexplate.
To keep the converter from falling out, I cut a length of 1/8" x 1" flat steel & drilled holes in it that bolt to a couple of bellhousing holes. Pull the tranny back just a little, then bolt it up in front of the converter. |
05-04-2004, 09:30 AM | #15 |
did you get it out without problems?
05-05-2004, 07:27 AM | #16 |
I got it out....
I am not gonna lie, its was hard to do probably cause I did it by myself.... I got the new one in, and ran out of time to finish it up I still need to connect the TV Cable, cooling lines, and finish the 4th gear lockup relay switch...
05-05-2004, 09:55 AM | #17 |
at least you have all of your fingers. and that deserves an attaboy.
