Old 05-03-2004, 04:20 PM   #1
Deuce
Deuce's Avatar
Will Newer 6 Bolt wheels fit on a 68 Chev??
Will the wheels off say a 2002 chev truck with a 6 lug design bolt on a 67-70 chev 1/2 ton??
Take-off wheels are pretty cheap.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 05-03-2004, 05:57 PM   #2
Faster_than_you
yep, they will, make sure your spacing is 6x5.5
~Christopher L. Orr
71 c20, 454- Stolen While Deployed. dynoed at 550 ft lbs, 425 hp at 3000 rpm (mustang dyno). TH400 3500 stall.... etc, etc.
Faster_than_you is offline   Reply With Quote
Old 05-03-2004, 06:11 PM   #3
Bolt pattern is the same
Off set might be OK, depending on the wheel.
The main holding point is the center hole. The new ones have a smaller hole. Again depends on the wheel on whether they will work with out modifying or not. It's an easy fix. Just have the centerhole machined out. (double check your backspacing first before you spend the machining money).
Old 05-03-2004, 06:11 PM   #4
greasemonkey
greasemonkey's Avatar
Maybe I am wrong here, but didn't somebody here do that and ended up machining the centers of them to clear the hubs? Or did I dream that?
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 05-03-2004, 06:13 PM   #5
greasemonkey
^He beat me to it.
Didn't Wes put later model wheels on one of his trucks?
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
Old 05-03-2004, 06:16 PM   #6
And you Florida folks thought all us Mississippi dudes were slow!@!
Old 05-03-2004, 06:24 PM   #7
Deuce
Deuce's Avatar
Thank you all sooo much
Take off wheels are falling out of the sky up here in Calgary. And I would imagine the aftermarket would also have tons of wheels for newer trucks!!
I was going to convert to 5 lug just for a better selection of wheels. This saves me a ton'o'work.
Old 05-03-2004, 06:47 PM   #8
70 longbed
You may have problems with the new take off wheels. As mentioned, you have to have the center holes machined. Also, there is no offset in these wheels, and they will rub on the tie rod end, and depending on tire size will rub on the frame before you get the wheel turned all the way. They go on the rear just fine, and they do look good.
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 05-04-2004, 12:17 PM   #9
Deuce
Deuce's Avatar
So with the wrong off set the wheels will rub on the tie rods?? I can get a set of 2004 chevy tahoe wheels c/w cap and nut covers for $300 Canadian,but if they are going to rub thats still not a good deal.
Ohh well, it was a good thought.
Thanks guys.
Old 05-04-2004, 12:23 PM   #10
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
Yes, they'll fit (assuming your backspacing is correct), but you WILL have to machine out the center hole. I know Bumpster actually tried mounting a new style wheel on one of his 67-72 a few months back. The center hole was too small and I seem to recall him telling me that there was something about the way the wheel mounted that caused the hub to carry the weight rather than the lugs. I'm sure he'll chime in with details/corrections.
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 05-04-2004, 01:27 PM   #11
Deuce
Deuce's Avatar
Machining the center out is no problem as I deal with 2 shops daily. The tie rod rubbing on the rim is a bigger concern.
Bumpster, any exp on this issue??
Old 05-04-2004, 03:58 PM   #12
smitty62
smitty62's Avatar
I'd like to hear more on this too, from people that have actually tried or done it.
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 05-04-2004, 04:43 PM   #13
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
I am in the process of doing it. I have some 17X8 with 5.5 backspacing. They will fit in the back but they rub the tie rod. I am going to put some 1.5 inch spacers to make them hubcentric. One inch spacer in the front should be enough but I am going with 1.5 or 1.25 to be safe.
I do know that there are some concerns about spacers. If you use a good metal say 6061 aluminum I think you should be fine. By adding the spacer to the set up of the wheel and axel you are realling not moving the moment of the wheel on the axel because you are just pushing the wheel out to the original distance.
I will have more to comment on this in the following weeks. ColoradoK5.com also has some info on the topic. Many 4X4s use them and I haven't heard any problems.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 05-04-2004, 06:35 PM   #14
70 longbed
I have tried this. I have a set of wheels from a 03 Tahoe that I was going to use. I picked up a 5th wheel to play with some minor damage to use as a test wheel. I honed out the center so it would fit and have had the wheel on the rear without problems. When I put it on the front it rubbed the tie rod end, and also the tire rubbed the frame when I turned it far enough. This is with a 235x65x16 tire mounted. I do think that a spacer, with longer studs may solve that problem, but question the use of a spacer? I guess that I should do some more research on the spacer.
This is on my 70 C10. It may be different on another year, but I would think that they are the same. If someone else has suceeded at this, I would like to know what they did.
Keith
