05-03-2004, 04:23 PM | #1 |
Space Saver Spare
Does anyone know if there is a space saver Spare Tire out there for that will fot a 73 - 80 Chevy 1/2 ton pickup??? I have a full size spare for my Lowered 78 Short Fleetside. Because my truck is so low, I hit a bump in the road, & ended up tearing the stock tire carrier out from under the truck and drug it and the tire a block or two before I could pull over!! Now I would like to find a smaller Space Saver type tire that will fit my pickup.
Any Ideas??????? Or am I ToonMan
Rob the ToonMan 56 Chevy Cameo----Custom, [Turquoise] 67 Chevy C10 Short Fleetside (Black & White) 63 Trailorboat-------Teardrop Style Trailer 69 Honda CM90 |
05-03-2004, 04:34 PM | #2 |
i think you are just could try a very narrow rim and skinny tire, say for like a trailer... i dont know.
05-03-2004, 04:38 PM | #3 |
been here longer than Liz
I removed my spare back when I lowered the truck & added the roll pan. I found a convenient area for the spare not far from it's original locale. It seems to have fit nicely, with room to spare, in the bed.
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
05-03-2004, 05:26 PM | #4 |
most trucks come with full size spares and there arn't many cars out there with a 5x5 bolt pattern like our trucks. the only one that comes to mind is the mid 90's impala ss. they had the same bolt pattern as our trucks but i'm not sure if they have a space saver or full size. i know those shared alot with caprices and road masters, but i'm not 100 % sure if those last 2 cars were 5x5 like the imapla or 5x4.75 like most other gm cars.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
05-03-2004, 06:36 PM | #5 | |
Trucker.
I would just stick it in the bed that's what most do. |
05-03-2004, 11:18 PM | #6 | |
05-04-2004, 04:06 AM | #7 |
'71-'76 GM big cars also had the same bolt pattern. A friend of mine used the spare from his '82 Buick Park Avenue (205/75-15) on his '75 C-10. Looked kinda puny, but it worked. Not all of the '77-up cars used the big bolt pattern though.
05-04-2004, 05:18 AM | #8 |
Well that helps!! Thanks Guys!!! Right now mine is in the bed and I HATE IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I know I am I think a space saver would do me just fine!!! I'd even trade one of my custom drawings for one!!!!!!!! Anyone with one want a custom drawing of their truck????
SQUATCH ART SITE -----> www.chevytrucks.org/squatch-art HOT ROD TOONS -----> http://groups.msn.com/ShadowsoftheNi...rt.msnw?Page=1 GM TRUCK TOONS -----> http://www.73-87.com/7387_Novelties/Toons.htm
05-04-2004, 09:45 AM | #9 |
Hay why not scrap the GM spare suport and get one off of some of the newer trucks. It has a crank deal under the bed so nothing hangs lower then the tire. My 84 Runner has one and it actually work rather well. It has a hole just below the gate that you stick the jack crank into and crank it up and down. No need to lay in the dirt.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
05-05-2004, 02:54 AM | #10 | |
Stepsides Are Bedder
05-05-2004, 03:19 AM | #11 |
I talked to my friend with the '82 Park Ave. today & he said the Buick originally came with a mini-spare, so you might dig one up at a wrecking yard. Just be sure the bolt circle is right before you buy.
05-05-2004, 01:40 PM | #12 |
Mudslides 'r my specialty
How about a 15X6 rally wheel off of a van with a 205/75-15 or something similar? That might work.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
05-06-2004, 02:31 AM | #13 |
I may end up doing the smaller truck wheel. But since my 78 has a 6 banger and I plan on keeping it in there, I could mount a space saver under the hood!!! Plenty of room in there!!!!!!!
just an Idea!!
09-04-2004, 01:53 AM | #14 |
I tried the Newer Crank Up spare mount under the bed and the tire still hangs Way Too Low!!!!!! I have hit all of the local wrecking yards and no luck in finding a space saver!!!!!!!!!!!!!!!!! I guess I am stuck with hauling it in the bed!!!!!!!!!
09-04-2004, 10:38 AM | #15 |
Happy to be here
Since your truck is lowered, here's another area of concern. Will your stock bottle jack work? Mine was dead anyway, but I knew if I blew an airline my truck would be too low to get the stock jack under it.
I bought a scissor jack from an 88-98 GM truck and put it behind the seat. It will go under my truck even with all the air out....
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 09-04-2004 at 10:40 AM. |
09-04-2004, 12:45 PM | #16 |
Stepsides RULE
lol yeah my truck ain't lowered yet and i don't have a roll pan, but i should stick my spare in my bed because the sheet of plywood acting as my bed has curled real bad and i got a cinderblock and 2 deterrgent bottles holding it down
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
09-04-2004, 11:28 PM | #17 | |
Insert Witty Text Here
Slonaker |
09-04-2004, 11:45 PM | #18 | |
09-05-2004, 12:22 PM | #19 |
the old hemi cudas had a space saver spare. it was just a rim mounted in the trunk.....no tire. lol
'67 c10 350/th350 |
09-05-2004, 01:05 PM | #20 |
Tonawanda 454
wow its a truck right?
umm trucks have beds right? what is the purpose of having a truck bed and not using it? seriously alot of the lowered/chopped trucks that i have seen use a tonneau cover and keep the spare on a custom bracket inside the bed either in front or behind the axle. some stand it up right behind the cab in the box, some use a spare tire casing from a full size van, paint it and mount it standing up in the bed usually on the sides... just a few ideas
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
