Old 05-04-2004, 06:14 AM   #1
1986Silverado
What I drive
1986Silverado's Avatar
won't start!
Got in my truck this morning to come home from work and it would not start. Would not do anything. It started fine when I went to work yesterday. Lights came on and were bright as if the engine were running. I think maybe the starter or ignition switch. Are there any other things it could be? Also what does the volt guage supposed to read with the key on engine off? Mine was reading like 8 or 9 volts! By the way this is on the 85 I have that is for sale, not the 86 in my sig. Please help.
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 05-04-2004, 08:24 AM   #2
jared stewart
Silverado Stew
jared stewart's Avatar
Do all the easy stuff first. Check all your fuses, fusable links. If you have a voltmeter check to make sure your getting juice to your starter. Make sure your getting good ground. If you think it's the ignition, run a wire from the positive side of your battery to the dark purple wire that goes into your firewall wire block. I'm sure other people will come up with better ideas.
- 1997 3/4 Ton Ext. Cab LB 4x4 6.5L Diesel
- 1979 3/4 Ton Longbed 4x4 "Farm Truck"
- 1984 1/2 Ton w/ '99 Vortec 350/700R4 2x4 FOR SALE
jared stewart is offline   Reply With Quote
Old 05-04-2004, 09:24 AM   #3
hotrodhomi
hotrodhomi's Avatar
do you hear any clicking when you turn the key over? do you have a hand held voltage meter?
hotrodhomi is offline   Reply With Quote
Old 05-04-2004, 10:10 AM   #4
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Check the neutral safety switch / or clutch switch (if manual) could try putting it into neutral (if auto) an see if it starts.
NeCrOmAnCeR is offline   Reply With Quote
Old 05-04-2004, 02:44 PM   #5
1986Silverado
What I drive
No clicking from the starter. I will try the wire idea Jared. I also put it in neutral and nothing. I'm stumped Also by the way the volt guage is good it read 14 volts when running. So what's is suppose to read when the key is on engine off? Thanks guys
2006 Chevy Equinox
Old 05-04-2004, 02:48 PM   #6
Low87on20s
Live from Atlanta
Low87on20s's Avatar
my 87 did this once. I changed the battery cables and all has been fine since.
Paul
Low87on20s is offline   Reply With Quote
Old 05-04-2004, 02:50 PM   #7
1986Silverado
What I drive
It was dark when this hapened this morning. I will check those cables when
I get to work thias afternoon.
2006 Chevy Equinox
Old 05-04-2004, 04:17 PM   #8
hotrodhomi
hotrodhomi's Avatar
your battery should have at least 12.5 volts when the truck is off. also check on the battery post, as well as the end of the cable, because you my have a bad connection.
Old 05-04-2004, 05:24 PM   #9
1986Silverado
What I drive
So with the key on engine off the guage should read at least 12.5 volt...is that correct? I checked the cable connections at the battery and they were tight. Will check the other end today. Thanks
2006 Chevy Equinox
Old 05-04-2004, 06:13 PM   #10
Opper77
Ob-Gyn Kenobi
Opper77's Avatar
Like above, check the fusible links. I had the same problem not too long ago...also, does your heater motor come on when you turn the key to "on" (make sure its on on your controls) If not I'd suspect the fusible link more closely 'cause they're on the same power supply wire...
'85 GMC Shortbox...
I used to have a firm handle on life....then it broke off.
Opper77 is offline   Reply With Quote
Old 05-05-2004, 08:42 AM   #11
1986Silverado
What I drive
Well got to work yesterday and the damn thing fired right up. Cranked right up this morning also. All the cables and links look fine. Everything is also tight. I have one question.....There is a wire the runs off of the positive cable to the radiator support....looks like a ground wire. What is that wire for and would that cause porblems if it was bare and touching metal?
2006 Chevy Equinox
Old 05-05-2004, 11:30 AM   #12
Opper77
Ob-Gyn Kenobi
Opper77's Avatar
You shouldn't have a wire from your pos. terminal straight to ground.. that would be a dead short....
'85 GMC Shortbox...
Old 05-05-2004, 05:05 PM   #13
1986Silverado
What I drive
Just went and looked at my 86 and you are right it is from the negative cable. What if that wire is exposed and touching metal? I will check and be sure it is on the negative side on my 85 when I get to work.
2006 Chevy Equinox
Old 05-05-2004, 06:51 PM   #14
Opper77
Ob-Gyn Kenobi
Opper77's Avatar
If the ground wire is bare and touching metal, it wouldn't be the end of the world I don't think BUT you could start arcing it out and blowing a fuse and/or link. Tape it up as best you can and then start checking your fusible links. Do a continuity test from either side of the links (there is one on the firewall next to the wiper motor, and 2 or 3 right close to the starter on the wires coming off it...(my problem was near the firewall one))
'85 GMC Shortbox...
Old 05-07-2004, 10:41 PM   #15
79scottsdale
my 79 scottsdale is having the same problems, i hear the clicking noise and all that but i dont have any idea what it was, i saw a cable ocming off of my neg. cable and it was coated in yellow coating but after about 10 secs. of trying to start it up, i somehow melted the yellow rubber coating right off of it!!!!!!! i dont know what the hell is wrong with it but i need to know soon bc its my DD and im tired of riding the bus to school every morning, especially since im a junior in high school!!!!
thanks,
joe
79scottsdale is offline   Reply With Quote
Old 05-08-2004, 07:55 PM   #16
TOMMAY
If the small wire from the neg cable to the radiator support is overheating,it means your main ground is bad.They can look ok but be rotten inside.Had the same problem with mine recently,intermittent no start,but good lights and that was the problem.Like to have drove me crazy. Replaced the ground cable and bingo no more problems.
Good Luck
Tom
76 Silverado
74 Vette
TOMMAY is offline   Reply With Quote
