Old 05-04-2004, 11:46 AM   #1
atcavage
Squeaky clutch
My clutch pedal has been squeaking recently. It sounds like it's coming from the spring area, but I see no problems at all and it only happens when I push it in all the way. I can hear a normal squeak and movement when I push it in, but at the extreme end of the push, it squeaks real band and makes a sort of grinding pop. Ideas?
1972 1/2 ton Chevy C10 V-8 350, crate engine, with Flomaster dual exhaust. She's Old Blue the Truckinator (no relation to Arnold )
atcavage is offline   Reply With Quote
Old 05-04-2004, 12:00 PM   #2
1969 GMC
1969 GMC's Avatar
sounds like you need to lube the clutch linkage...get under the truck and put the grease gun on it, and pump until you see new grease come out. mine squeaked too, and after i did this it stopped. it also worked smoother, too.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-04-2004, 01:23 PM   #3
charles oliver
68 camtruck
charles oliver's Avatar
Squeaky Clutch
It could be the Throw out bearing going bad. Is it sort of squeaky but can you feel a rubbing in the clutch pedal.
Charlie
71 GMC Jimmy 4X4
68 Huger Orange Camaro 454 with TH400 :gmc
charles oliver is offline   Reply With Quote
Old 05-04-2004, 01:30 PM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Does it sound like its inside or out? The clutch rod runs though the brake pedal mech, lube all that too and where the spring makes contact.
sneakysnake is offline   Reply With Quote
Old 05-04-2004, 01:46 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
To add to sneakysnake, their should be two plastic bushings at either end of the shaft that connects the pedal to the rod that goes through the firewall.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
