Old 05-04-2004, 03:27 PM   #1
GMC71k20
which liftkit brand
one of my front leafpacks is starting to sag pretty bad. makes my truck sit crooked about 1.5" now. this is good cause now im forced into buying new springs for it. i wanna go with 6" springs all around. this is just a pavement pounder so ride quality is the main objective. ive heard that skyjacker offers a soft ride. does anyone know where the best place to buy skyjacker is. also what parts should i need after lifting another 2". I'm planning on replacing my driveshafts since the rear is warped a little.
GMC71k20 is offline   Reply With Quote
Old 05-04-2004, 07:30 PM   #2
ryanroo
ryanroo's Avatar
i have the 8 inch skyjacker, and it isn't to bad, but as with all lift springs it rides a little choppy, im sure the 6 inch will be better though. i bought mine from a smaller company in michigan i want to say, called kersteners 4x4. the only advice i can give is to call several dealers and see what they include in their advertised price, some may have shocks and brake lines while others don't. with a four inch lift you can usually make factory drivelines work, but with 6 theyll need replaced, so if you replaced them with the 4" then you will most likely be OK, same with shocks. certainly want to make sure your brake lines have plenty of room to work. or they will need replaced too
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-04-2004, 08:18 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
http://www.truckworld.com/How-To-Tec...uspension.html
Enjoy!
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-04-2004, 11:39 PM   #4
stan79chevy
stan79chevy's Avatar
this guy is on ebay
the prices seem reasonable i havent bought any from him yet if you do let me know how his stuff is.
stan
http://stores.ebay.com/Davys-Offroad-Products
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
