Old 05-04-2004, 04:04 PM   #1
CHEVYE
my gas saver
CHEVYE's Avatar
any ideas on weight of truck????
i got a g tech meter and need to know how much my truck weighs. it is an 87 swb, big block, 400 turbo trans, and dual tanks. anybody know?
CHEVYE is offline   Reply With Quote
Old 05-04-2004, 04:11 PM   #2
DCRANER
I have an 86 GMC swb with a 350 small block, Turbo 400, and dual tanks.
Recently I weighed it at the drags with both tanks about 3/4 full and it weighed 4,250. These trucks are HEAVY.
Thanks.
86 GMC SWB, DK. BLUE, ZZ430,TH400, 4.11'S, HEADMAN CERAMIC HEADERS, WELD BILLETS, BFG 275 / 60 / 15, 325 / 50 / 15 DRAG RADIALS, FIBERGLASS COWL HOOD, B&M SHIFTER. MSD, MARCH PULLEYS / ALT. / PWR. STEER PUMP, BECOOL RAD., BILLET GRILL & GRANT WHEEL.
DCRANER is offline   Reply With Quote
Old 05-04-2004, 04:21 PM   #3
CHEVYE
my gas saver
CHEVYE's Avatar
hey thanks a ton. i think they will be about the same with a tankful or so in mine. the motor may weigh another 150 lbs. or so i would guess. i can`t wait to try this thing out.
Old 05-04-2004, 11:57 PM   #4
TIMSPEED
TIMSPEED's Avatar
In my sig....
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 05-05-2004, 12:59 AM   #5
Russell
Professional Grade
Russell's Avatar
Mine is 5500 lbs with two full tanks of fuel, myself, my brother, some sound equipment, and my tow strap kit...
C25 350 / TH400 / dual tanks / 14 bolt rear end with HD springs and leaves all around.
Yeah, shes a heavy girl, hehe
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 05-05-2004, 01:13 AM   #6
plumbcut
california fill
i say enter a weight in the Gtech, run it and if you dont like the horsepower reading, adjust the weight.. hmm only 375hp? that cant be right, lemme tag another 800lbs on there ....
pc
plumbcut is offline   Reply With Quote
Old 05-05-2004, 09:54 AM   #7
CHEVYE
my gas saver
CHEVYE's Avatar
that`s a lot of difference between 3650 and 5000. plumbcuts idea sounds good to me. i really just want 1/4 times mostly and that won`t matter on weight. the truck has a 273 gear (i believe). it will roll 130 on the interstate but it takes a minute to get there. is there anything in the vin to see what gear ratio it is?
Old 05-05-2004, 10:04 AM   #8
DCRANER
Whoa, 2.73 rear with Turbo 400? That will not get it done in the 1/4 mile.
You would need a 700R4 trans., which has a very low 1 st. gear, or change the rear gears. I have a 3.73 rear with the Turbo 400 and am in the process of going to 4.10's.
Plus how tall are your tires? Mine are 28" tall, if you have a tall tire, 29,30 etc tall that will have the effect of hurting a low gear ratio.
Your combo is for Talladaga, not the 1/4 mile.
Old 05-05-2004, 11:33 AM   #9
Grim Reaper
hehehe I got a Jimmy on 35's with hard top, trail gear, full tank of gas and my fat A$$ that tips the scales at 6640lb.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 05-05-2004, 11:34 AM   #10
Grim Reaper
http://www.tatravelcenters.com/ta/di...ml?page_id=534
See if there is a scale near you.
Do a serach on Google for Truck Scales.
Grim-Reaper
Old 05-05-2004, 11:47 AM   #11
apstguy
LED King
apstguy's Avatar
I'm under 4000 - 3800 pounds!
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 05-05-2004, 11:57 AM   #12
DCRANER
My 86 GMC looks just about like your truck in your website, so how can you be at 3,800 lbs. compared to my 4,250 lbs.?
I cannot imagine I have 450 lbs. more. I have even removed the A/C, engine has alum. intake & heads, and alum. wheels, and a fiberglass hood.
Any idea?
Thanks.
Old 05-05-2004, 06:15 PM   #13
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
My 86 4x4, with dual tanks, one full, one with fumes, about 600 lbs worth of people, and 33's weighed in at 5306 lbs.
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 05-05-2004, 07:41 PM   #14
swervin ervin
You get what you pay for
swervin ervin's Avatar
Last time I weighed mine, it was 3960. I didn't have aluminum wheels, heads and other stuff then either. I imagine, it's probably in the 3850 range now. I need to get it weighed again.
A good place to weigh it is at a landfill.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 05-05-2004, 08:52 PM   #15
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Wink
I had mine weighed in jan '04 and it was 3780 but mine is a stepside and i have aluminum rim's and fiberglass hood and i wasn't in the truck and i had about a 1/2 tank of fuel.
I got it done at a flying J truck plaza for 7.50$ and the scales are certified & calibrated.
Note: When you weigh a truck you don't include yourself or the fuel these item's are not considered part of the operating weight so they should be deducted to get the actual weight of the truck.
Use 6.7 to 7.0 lb's per gallon for the fuel depending on what the temp is at the time.
But for what your trying to do you may want to add thoes items to get an accurate 1/4 mi time.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 05-05-2004, 09:58 PM   #16
C-10volvo
C-10volvo's Avatar
with my 84 lwb single almost empty 20 gallon tank, i tipped the scale at 3850. this was without the massive amounts of stereo stuff and a fairly stripped interior.
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
