Old 05-04-2004, 04:09 PM   #1
Budweis
Geared for Collision
Budweis's Avatar
frame cross brace
On the frame of my truck nearest the back bumper there is a frame cross brace that connects the frames together that is mangled and ripped out most of the rivets that hold it. question is does anyone have this brace piece for sale or know where i can get one through the mail or net. like i said its the one nearest the back heres a pic. i know i could search the bone yards but the nearest one like 50 miles away and would rather find one could have delivered.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB
1970 C/K20 3/4 Ton
1996 Collectors Edition Corvette
1977 Corvette Coupe
Budweis is offline   Reply With Quote
Old 05-04-2004, 04:24 PM   #2
hilbilly
I do everything twice, so what
hilbilly's Avatar
Location: To the Right. One may go as far to say WAY to the Right
What is the length? We've got 3 or trucks I could cut one out of tonight
hilbilly is offline   Reply With Quote
Old 05-04-2004, 04:51 PM   #3
Budweis
Budweis's Avatar
looks like 33 inches at its longest spot at the bottom and on the top of frame frame where connects there is only one rivet on each side and from the top rivet holes in frame the distance is 31 1/2" and on the bottom there are 2 rivets on each side and from farthest out ones the measurement from hole to hole is 31 and 3/4" my measurements could be just a bit off as its pretty bent but they got to be close. let me know this would be great
1970 C/K20 3/4 Ton
1977 Corvette Coupe
Old 05-04-2004, 04:55 PM   #4
hilbilly
hilbilly's Avatar
We hacked up a '70 something 3/4ton frame last week, I'll check it out. If not there's another couple I'll look at.
Old 05-04-2004, 07:09 PM   #5
Budweis
Budweis's Avatar
just got it out and snapped a few closer up pics of it.
1970 C/K20 3/4 Ton
1977 Corvette Coupe
Old 05-04-2004, 08:23 PM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Not to highjack this thread but since we are talking about items that require a donor truck, hilbilly, do you have the front spring hangers for the rear springs from that 71?
Budweis I believe you'll need to find a donor vehicle which it sounds like hilbilly might have you covered.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-04-2004, 10:57 PM   #7
hilbilly
hilbilly's Avatar
I guess my stuff must be newer. the overall length is 33", but the one useable one we got has two rivit holes on the top. If you think it will work, let me know and you can have it.
Old 05-04-2004, 11:05 PM   #8
hilbilly
hilbilly's Avatar
Jims70GMC, most of the stuff we have is mid to late 70's, here's a pic of the lastest. It's getting a new power plant (again). The blue one is a '88 1/2ton body we swaped to a 70 something 3/4ton frame with corp 14 ff and D44 upfront
Old 05-05-2004, 12:05 AM   #9
Budweis
Budweis's Avatar
if it measures 33" and tucks between the frame rails it will prob work. does it look similar to pics above? the height top to bottom bolt holes somewhere around 4 and 1/2 inches. if the same dimensions i could definitely use it. just pm me let me know so we can set up transaction.
1970 C/K20 3/4 Ton
1977 Corvette Coupe
