Old 05-04-2004, 05:22 PM   #1
68 Suburban
68 Suburban's Avatar
Question Trans Cooler Question for the Burb.
I know I asked this before, but I can't find the post.
When running a trans cooler, do you still need to run the lines through the radiator? The instructions usually show the cooler run in tandem with the radiator cooler. What reason would you still need to use the radiator cooler? Thanks in advance.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-04-2004, 05:51 PM   #2
ckhd
ckhd's Avatar
Yes, you do need to run it through the radiator. The radiator is not just a cooler, but a temperature controller.
Also, even a LARGE accessory cooler isn't enough to control the temperature.
I do know that when I put a 700r4 in my 'burb, then Bowtie Overdrives absolutely insisted that I run it through the radiator too. Said they wouldn't warranty it if I didn't.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 05-04-2004, 06:35 PM   #3
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
For racing, use it by itself, for a daily driver use the radiator cooler along with the aftermarket cooler. In my 83 El Camino I am running a B&M super cooler with a fan by itself. Running it through the radiator cooler is supposed to keep the temp at a constant rate.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 05-04-2004, 09:37 PM   #4
68 Suburban
Thanks, does it matter what line you run to where?
Trans running to the cooler then the radiator, or vise versa? Which trans line is inny and which is outty.
Old 05-04-2004, 10:10 PM   #5
Duallie
Duallie's Avatar
The bottom line pumps FROM the tranny; the top line (at the transmission) is the return. I run from the trans to the new cooler then to the radiator. That way, no extra heat is dumped into the radiator from the transmission, and the return oil is always engine temp. No more, no less. In Alaska, it can be a LOT less.
Duallie is offline   Reply With Quote
Old 05-05-2004, 11:51 AM   #6
ckhd
ckhd's Avatar
And you want to pump the fluid from the bottom to the top in your radiator and your cooler (inlet at the bottom).
I go from the tranny to the radiator, to the cooler, then back to the tranny.
I don't know if running it to the aftermarket cooler first would be best or not.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 05-05-2004, 12:35 PM   #7
mrein3
mrein3's Avatar
68 Suburban,
Your signature shows you live in Phoenix. You want to run your hot tranny fluid from the tranny to the radiator to the external cooler then back to the tranny. You only have to worry about heat.
Up here in Minnesota we run them to the radiator AFTER the external cooler to HEAT the fluid in the winter.
The ultimate solution is to have plumbing and valves to be able to do both.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 05-05-2004, 03:12 PM   #8
68 Suburban
Thanks for the help
