Old 05-04-2004, 07:51 PM   #1
Budweis
Geared for Collision
Budweis's Avatar
jack stands
what are you guys with 6" lift using for jack stands in the back, i need to get it up off the ground completely but having a hard time finding some jack stands. i seen one set but they wanted 500.00 for lol cant afford that im on a small budget. i want something safe definitely as i'll pretty much be living under there for week or so. i think my jack with few timbers will be ok to get it up there just looking for soulution for jack stands. and i cant weld anything up for it as only got a 110 mig so wouldnt be solid enough. measured it and looks like would need 35" or higher jack stands. if anyone knows where to locate these for decent price and could link or info would be appreciated.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB
1970 C/K20 3/4 Ton
1996 Collectors Edition Corvette
1977 Corvette Coupe
Budweis is offline   Reply With Quote
Old 05-04-2004, 08:11 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Are you trying to support the rear by the frame w/ tires on?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-04-2004, 08:43 PM   #3
1FaastC10
1FaastC10's Avatar
i've got 4 of the saem jackstands, and plan on finding a piece of 8" I-beam to make some risers out of for when my truck gets a little taller.
1FaastC10 is offline   Reply With Quote
Old 05-04-2004, 10:42 PM   #4
Budweis
Budweis's Avatar
lol i must have bumped my head , thanks jim i was trying to set behind rear end was prob, i have the same stands as well and just measured and they should work fine.
1970 C/K20 3/4 Ton
1977 Corvette Coupe
Old 05-07-2004, 09:33 PM   #5
Joey-D
City's Articulation Ramp
Joey-D's Avatar
I used 3 ton stands from autozone
85 K90 SWB Rockwells 46x19.5 on double beadlocks 20" lift 305/sm465/NP208 Toy
00 Silverado 2wd SWB 4.8 auto 3/4 drop slamair bags esclade rims Daily Driver
06 Harley Sporster 883 low
19?? Zamboni, Really I own a Zamboni!
"If your gonna be stupid, then you better be tough."
Joey-D is offline   Reply With Quote
