sold
Finally got my york mounted
its on a burban but that thread is not very busy so ill post it up here.
Signals in the bumper.
Whats next?
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
What is it?
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
sold
next i need to plumb the lines for the air tank, and put in the bags. switches and stuff are already wired.
gldevall- its a air compressor for my air bags |
been here longer than Liz
Nice job, was it an easy install?
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
Is it already converted to internal oiling? Where did you get it and how much?
I saw a York in operation this past weekend and I was not too impressed, but it was still cool. Granted, it was having to supplying 10-15 gallons of air for for a bodydropped suburban with 1/2" lines and FULL lift (to stock 4x4 height). Since the clutch is kicking off and on, you have to wait for the clutch to engage to fill the tanks.
#7 | |
Needs bigger lines and a tank then. York can make 300psi no problem. It's like 9 CFM at 90psi and 1500 Engine RPM. One mistake I have seen people make is the plumb the presure switch inline close to the compressor. Then down stream before the tank there is restriction like a fitting that necks down. The York will make the air fast enough the the line pressure will hit 125psi (cut off on most switches) and just keep cycling even though the tank may be at 50PSI. BIG FAT pipe with no restrictions before the tank and it should do pretty good. Running straight off tthe compressor with a 1/4 in ID line it will fill a 35 inch tire from 10PSI to 30 in about a minute at a 800 RPM idle. That as fast as my home compressor will do it.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
www.loweredd.com
Looks good! I gotta measure mine for the new belt, and that's about it. I should snap a pic.
Good job! |
which vehicle did you get that from, cause i need one that is serpentine belt driven instead of the V belt driven that i can only find
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
full foot
CJ's I believe had them, but here is a link to one that is serpentine. http://www.onboardair.com/clutches.htm bagged81 That is weird that he was having problems. I have seen air tools run straight off a 10 cu. in. York compressor.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Trucker.
Nice.
![]() Early 80's Volvos and Fords had them as well. |
