05-05-2004, 12:10 AM | #1 |
Got Light Emitting Diode?
tail gate
has anyone out there modified their tailgate to the 73-87 style hindge that way you can take it off with out taking out bolts? i noticed the radius of the 1981 hindges are smaller. did you just weld some metal on to make it the same size? thanx
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
05-05-2004, 01:45 AM | #2 |
huh ???
My dad modified the original trunions and tailgate to make it a lift off style...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
05-05-2004, 07:10 PM | #3 |
did he have to change the radius? my 68 holes are bigger than the new brackets
05-06-2004, 12:13 AM | #4 |
huh ???
Used the original 69 brackets. Pic 2 shows how he cut the right one and put flat metal back onto it to strengthen(sp) it back up...
Chuck
05-06-2004, 04:14 PM | #5 |
its all about the +6 inches
How often do you guys remove your tailgate?
I've had mine off twice in 3 1/2 years. |
05-06-2004, 04:46 PM | #6 |
huh ???
I take mine off every time I have to sweep the leaves out of the bed...
Chuck
05-06-2004, 07:32 PM | #7 |
You can't just sweep them over the opened tailgate?
05-06-2004, 09:27 PM | #8 | |
Bloo
i take mine off regularly-- its a pain to pull a gooseneck with the tailgate on imo. the 71 c10 has a 78 hinge (which IS smaller) but it doesnt rattle or anything, i just put the top bolt in (bottem wouldnt fit) and then tightened it down tight, and cut a slit in the trunion on the gate
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
05-06-2004, 09:48 PM | #9 | |
huh ???
Chuck
05-06-2004, 09:52 PM | #10 |
2 fullsize motocross bikes will not fit in a shortbox (if your into that sort of thing) unless you remove the tailgate and my streetbike will only fit on an angle without removing the tailgate as the wheelbases (on the bikes) are too long. My KZ 1000 (streetbike) weighs @ 500lbs and its a bit of a pain to get it on an angle so you can get the tailgate to shut (a small price to pay for owning a short fleet IMO) Regards Doug
05-07-2004, 08:14 PM | #11 |
i have a roll pan on the back of my truck so it is impossible to get the bottom bolts in when the tail gate is on. plus the after market tail gate i have was just a little too narrow and kept sliding off of the hindge when it was down. i had to take it off to fix that so i might a well do the swap since i have a burnt down pile of junk (81 gmc)in my back yard.
