Old 05-05-2004, 09:55 AM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
Cool Well, she fits now
Well a little of this, a little of that and now that bad boy fits!
As some of you know, I am swapping in a 454 in place of the 307 and ran into major firewall problems.
In the end I increased the body lift a bit and as you can see made a few minor firewall mods.
My plan is to at some point go in and move the engine forward so I can go back down to the 2" body lift. This combined fix gets it where the body guy can get done, I can enjoy the truck and then when I'm ready for another project I can go in and move the engine forward.
To avoid having to move the engine forward the firewall mods would have ended up being pretty severe. I really can't see how some people are able to do a 3" body lift and light massaging on the firewall, though I know they have as I have seen pics.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-05-2004, 10:15 AM   #2
ts71281
Now you can set that timing when you're driving
Joe
ts71281 is offline   Reply With Quote
Old 05-05-2004, 10:17 AM   #3
ryanroo
ryanroo's Avatar
that looks pretty clean, how are you planning on patching the holes? it is kinda weird, because i got a 454 in mine with no body lift and i only had to bash the firewall in a few places for it to fit. keep the pics coming thanks
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-05-2004, 10:18 AM   #4
bigvinnie
bigvinnie's Avatar
I haven't worked with BBCs much, are the newer motors that much bigger than the original 402s that went in these trucks...???
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 05-05-2004, 10:20 AM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
Holy crap. That is some severe surgery there. I hope Doctor Boz-all was licenced in the state of KS. If not maybe you should sue for malpractice.
I did not envy the position you were in, I suppose a 292 was out of the question?
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 05-05-2004, 10:21 AM   #6
'70_402
'70_402's Avatar
OUCH..... Those really are some severe mods.... oh well at least the truck won't be out of commission any longer that need be.
'70_402 is offline   Reply With Quote
Old 05-05-2004, 10:26 AM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
bigvinnie, the 67-72 4wd's did not have a big block as an option.
CPNE, no sawzall here, just a good ole cut off wheel but I guess that probably does fall under Doc Boz-all territory. (At least my dash remains uncut!) With carpet this mod should not be too noticeable - unfortunately I just didn't have much in the way of options that could be done at the moment.
Ryanroo - the pieces that were cut out will be built up and outward a bit to cover the holes.
Old 05-05-2004, 11:45 AM   #8
orangeuavol
GO VOLS!
orangeuavol's Avatar
I will have to do the same thing to my '72 K5. Already test fit the 402BB and "rough" cut the needed clearance. Fits like a glove.
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
Old 05-05-2004, 12:34 PM   #9
Joe67
67 is sold
Wow - almost like a G-Van now
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 05-05-2004, 02:19 PM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
Plexiglass - hmmm.
Okay, j/k.
Old 05-05-2004, 04:18 PM   #11
Bowtie67
Bowtie67's Avatar
WOW!! I think I would have gone for the moving the engine forward first before having to touch the cab like that. Where you gonna put the gas pedal?
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 05-05-2004, 05:08 PM   #12
Yukon Jack
Post Whore
Yukon Jack's Avatar
I am probably going to graft in a throttle cable setup rather than the throttle rod setup that this truck had.
Old 05-05-2004, 06:04 PM   #13
Bowtie67
Bowtie67's Avatar
You may want to look at Lokar's Eliminator Floor Mount Gas Pedal
FMG-6097
This bolts to the floorboard and has a cable assmbly that mounts under floorboard. I dont think you will be able to draft any stock setup,
http://www.lokar.com/thottle_assemblies.html
2009 Toyota Tundra
Old 05-05-2004, 06:27 PM   #14
crazy longhorn
Fabricate till you "puke"
That reminds me of a couple holes I cut in the longhorn to fit a 455 Olds.....once you go "custom" you will never go back to stock best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-05-2004, 09:11 PM   #15
Jeepster376
Jeepster376's Avatar
I didn't know that, does a 2WD truck have a different firewall to accomodate the big block?
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 05-05-2004, 09:20 PM   #16
crazy longhorn
the firewall is the same on the cabs, just the eng positioning is different for the BB 2wd trucks. 4 wd sb sits in I 6 position(for 2 wd), the factory sb (2 wd sits about 3 1/2" farther ahead than the I 6, 2 wd , or sb 4wd. the BB comes somewhere tween those two spots on the 2 wd truck. crazyL
Old 05-05-2004, 11:20 PM   #17
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
I'll bet it was hard to bring yourself to start cutting on that beutifull cab!!
How much body lift does it have now?
BLAZERMAN is offline   Reply With Quote
Old 05-05-2004, 11:26 PM   #18
MACKL
Almost done!
MACKL's Avatar
You are a very brave man! If your brakes go out, you will have a Fred Flintstone hole to use to stop.
I hope everything works out.
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline   Reply With Quote
Old 05-05-2004, 11:53 PM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
It's only sheetmetal. This shows you "ain't skeert" to cut one up....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-06-2004, 10:56 AM   #20
Yukon Jack
Post Whore
Yukon Jack's Avatar
Blazerman - unfortunately the body lift had to be 4" - I will be moving the engine forward so I can get the body lift back down to 2" - but that will have to wait until I have more time for another project and $$.
Old 05-06-2004, 08:29 PM   #21
Quagmire
A splendid one to behold
Quagmire's Avatar
FMG-6097
OT, but anybody around here running one of these setups? i have been looking at this pedal for some time now, but wasn't for sure...
67 swb
02 wrx
Quagmire is offline   Reply With Quote
Old 05-07-2004, 12:58 AM   #22
Hooter
My other Love
Hooter's Avatar
hey its a good hole to spit out of or to chuck your sunflower seeds out of
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 05-07-2004, 10:04 AM   #23
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I think your rig needs some 38's now. To go with that lift. Good job.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 05-07-2004, 11:06 AM   #24
Yukon Jack
Post Whore
Yukon Jack's Avatar
I was thinking the same thing about tires. I will have a total of 11" of lift now Will reduce that down to 9" when I move the engine forward. The 35"s will look small! Gotta save some money but at some point the 35" tires will go on the K5 and I will put something a bit bigger on this truck.
Old 06-01-2004, 10:25 AM   #25
Yukon Jack
Post Whore
Yukon Jack's Avatar
Body guy got the sheetmetal work done on the firewall. The inside is going to be hidden mostly by carpet so keep that in mind as you look at the pics. I'm pretty pleased with how this turned out. I think the gas pedal is going to work well still, I was a little worried before.
Here is the inside passenger side
And outside passenger side
