05-05-2004, 10:50 AM | #1 |
Are the boxes on our truck adjustable?
Just wanted to know if it's possible to loosen up the box mounts on the frame and pull it back about 1/2" or so. My box is too close to my cab and around a sharp corner or turning into a hill where the frame flexes a bit, the box bolts that hold the side and front of my box will tap on my cap. I got a few chips on the cab and the box Perhaps my mounts are bad? I don't know! I don't want to drive it anymore until I get this fixed. Thanks!
Joe |
05-05-2004, 11:22 AM | #2 |
user # 2756
I don't know if you'll get 1/2" but it could move a little. You could also move the cab forward.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
05-05-2004, 12:59 PM | #3 |
How many bolts is it to take the box off? Maybe then I'd just elongate the holes and make the box adjustable I don't want to loosen up the cab and try sliding that.
Joe |
05-05-2004, 03:27 PM | #4 |
ttt, no one else wants to chime in?
05-05-2004, 04:08 PM | #5 |
There are eight bolts that hold the bed on the frame, they are 3/8 bolts, There is a little room to possible slide it back but not much. You may be able to get a 1/4 of an inch, but that will all depend on where every thing is at now. I would check all you bushing mounts and make sure there are none missing or totally squashed which could also appear to put the bed and cab close together.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
05-06-2004, 04:22 PM | #6 |
its all about the +6 inches
Ypu may want to look at your cab mounts, this is a good sign that they are falling apart.
05-06-2004, 04:51 PM | #7 |
Too many is never enough!
bed header bolts
Another thing to consider would be swapping out those header bolts. Chevy used both a hex head bolt and a #3 phillips. If you have the hex head, swap it for a phillips and you'll get a little more room plus no corners to knick the paint. This problem seems to be more prevalent on short beds.
Jason 1968 K10 SWB Fleetside 1971 K2500 GMC LWB 1968 K20 (later frame, donor body) 1972 C20 LWB parts truck 1993 K2500 Suburban, tow rig, 454, 4L80E NEW!! 18' Siem's car hauler 2004 Honda Odyssey (family man!) |
