71 DELUX
OK, for those of you with wood beds... what is the size of those old square nuts one the underside of the bed bolt strips? And, what is the secret to getting them removed. I am thinking that a socket end could work if it has the right notches, but what size socket can I get on that square nut? Do I have to buy a special "nut removal" tool (so-to-speak)
![]() Join Date: Mar 2000
Square nut sockets are available. You'll probably break most of the bolts. Some will spin on the top side, grab em with vise grips or tack em to the flange with a mig. Some will probably take a grinder and an air chisel to get out.
Saskatoon, Saskatchewan Canada |
After removing all the wood boards, hold the shaft of the bolt with vice grips. I used a 7/16" open end wrench (stand on end over nut). Then take a 3/8" open end wrench and turn the 7/16" wrench. Some will break, some will turn loose, good luck.
71 DELUX
Sounds like a WHOLE BUNCH OF FUN...not!!! Don't I need to remove all the nuts before I can remove the wood? Or can I simply get one strip loose, then slide the boards around a bit to access the bottom side of the next strip?
With the middle boards that's pretty much right but the outside boards are bolted through. If they are old and rotten you might be able to just rip em out. A Sawzall and a BFH can get most of the work done. If the bed you have is not a realy a gem then you can take a sawzall and cut the bolts after the wood is gone.
71 DELUX
Bed is nice, and the wood is even nice. It was painted yellow, then covered with a camper, so it is not split, rotted, bowed or anything...it acually might even be worth refinshing...that's how good the wood is. Want to preserve it as best possible.
go to sears and buy an eight point socket (7/16) and use some WD 40. that s all there is to it.
Spray them well with PB Blaster the night before and it will make the job a lot easier.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
AND HOLDING ON TO THE C10
i'm going to try something different on my 84 c10 the bolts are not worth the problem in removing them to keep, so i'm going to drill a 19/64 whole right in the center of the head on the bolt and use a 19/64 easy out and clamp some do it your self craftsman vise grips.and if that don't work i'm tack welding the head of the bolts to my bed floor and if that don't work I'm just going to my muffler shop and have joe heat them suckers up and take them out for about 20.00 and just put a couple new bolts in until i get back home for the life of me i can't understand why the factory put a bolt in with out a hex or allen head bolt so they could be removed a lot easier i know that's what i'm putting back in when i put my bed back on if anybody tries any of these solutions and they work or not let us know SACTOC10 if your wood is nice and you haven't got your bed of yet i would go with sollution 3 muffler shop
66 swb/ss chevy c10 ![]() 62 swb/fs chevy c10 :p SOLD 84 swb/fs chevy c10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() 91 sdime 383/th350 ![]() Last edited by truckman32; 07-11-2004 at 10:25 AM. |
71 DELUX
Yup, the more I see typical wood beds after all these years, the more I realize my wood is in very good shape. Thanks for the ideas.
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50 2003 FORD Escape 1998 Honda VTR1000 |
#11 | |
66 swb/ss chevy c10 ![]() 62 swb/fs chevy c10 :p SOLD 84 swb/fs chevy c10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() 91 sdime 383/th350 ![]() |
i always just take a grinder and grind the heads down and drive them thru with a punch takes about 30-45seconds per bolt
#13 |
I thought about grinding but it's almost inpossible to keep from grinding into the bedfloor and wood floors look awful after grinding into the wood
![]() http://hometown.aol.com/staindoutsid...age/index.html
66 swb/ss chevy c10 ![]() 62 swb/fs chevy c10 :p SOLD 84 swb/fs chevy c10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() 91 sdime 383/th350 ![]() Last edited by truckman32; 07-11-2004 at 08:08 PM. |
#14 |
![]() Join Date: Aug 2001
![]() I ALWAYS USE A CUTOFF WHEEL. IF YOU DON'T WANT TO TAKE A CHANCE ON SCREWING UP THE WOOD.... CUT FROM UNDERNEATH. ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
#15 |
![]() Join Date: Sep 2001
i pulled the bed and just grinded 'em all apart from the bottom. No risk of damaging anything pretty that way...
#16 |
there are many ways of doing this but this is the best way i have found .
#17 |
Before and After
If you don't want to buy a special socket, just take a peice of threaded rod and put 3 or 4 nuts on it to make a "Long nut", then take 2 sockets and match the working ends together over the long nut and there you have a 3/8" square socket.
I spent alot of time triing to remove the bolts that most of them brok or spun in the top strip, so in the last 5 strips, I just tightened them and it was alot quicker. I used 9/16 sockets because I thought that a stronger bolt was needed than the ones I was triing to break.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
#18 |
71 DELUX
WB72,
I can't visualize what you are describing... almost sounds do-able, but not quite getting it.
#19 |
Before and After
See if you can understand my rough drawing.
An artist, I am not.
#20 |
wb72 Carriage bolts is what he should have holding his bed down so they have the button head on them so there is no way to hold them from turning
#21 |
Cantankerous Geezer
Got torch?
Fred There is no such thing as too much cam...just not enough engine. ![]() |
#22 |
Before and After
Oh, my mistake. My only thoughts might be to smash them with a hammerfrom the bottom of the bed. Or as Fred T says torch em.
