Old 05-06-2004, 12:46 AM   #1
kilomanjaro
kilomanjaro's Avatar
Angry Cracked Bolt Hole In Block---Advice Needed
Ok, here is the story, my friend and I were bolting a power steering unit onto a 350 motor in a 72 pickup I am working on. When we were bolting on the power steering brackets, we used a bolt that was too long and an impact wrench that was too powerful! Bolt went throught the back of the hole and antifreeze started leaking out. Any advice?? Will RTV seal up the the threads and keep it from leaking? What about that chunk of metal, is is going to eat waterpumps now? Any advice would be greatly appreciated. Thanks
JOHN
63 Buick Wildcat 425
72 Chevy Blazer CST
72 Chevy C10 Cheyenne
00 Ford F-350 Super Duty 7.3L
09 Dodge Challenger SRT-8
10 Ford Expedition Limited
kilomanjaro is offline   Reply With Quote
Old 05-06-2004, 01:48 AM   #2
Jeepster376
Jeepster376's Avatar
That's not a good situation, but if you wanna give it a shot, I would put pipe thread sealant in the threads and RTV between the bracket and the block, and finish it off with a copper washer under the bolt head.
The broken chunk will most likely settle to a corner in the block and stay there.
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 05-06-2004, 02:26 AM   #3
RON WOODGEARD
Resident Young Old Dude !
I hate learning sessions
But I agree with Jeepster, threadsealer, and Silicone sealer. You'll be fine as long as it didn't break anything else..
RON WOODGEARD is offline   Reply With Quote
Old 05-06-2004, 03:37 AM   #4
Warrens69GMC
Warrens69GMC's Avatar
The best bet is thread sealant on a stud. (Don't want to say jb)
warren69gmc
Old 05-06-2004, 11:40 AM   #5
rickspickuppart
sealant
GM makes a stopleak that they use in the late models caddillacs to seal up the heads and stop electrolosis in the aluminum parts, I have used it in the past and it works alot better than alumaseal and doesn't build up and create sludge.
Shawn
rickspickuppart is offline   Reply With Quote
Old 05-06-2004, 12:11 PM   #6
cdowns
cdowns's Avatar
i agree with trying the thread sealer. i'd also suggest not using an impact gun again until you become more familar with it's proper usage
Old 05-06-2004, 03:01 PM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
Go to the parts store and get Permatex High Performance Teflon thread sealer.
http://www.permatex.com/products/pro...&item_no=56521
Also, if you want to use air tools, get an air drive ratchet, they are far easier to control.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 05-06-2004, 03:19 PM   #8
grayw0lf
Can I make a suggestion... Do not use an impact wrench for small things like that. Bad idea IMO. Try an air rachet next time. Impact wrenches are good for breaking stuff loose working w/ anything too tight for a long wrench. Other than that, I think I'd keep to my rachets.
Be sure to follow recommended torquing recommendations.
John
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 05-06-2004, 03:49 PM   #9
Crank
Crank's Avatar
You really dont gotta worry about sealing it up, every waterpump bolt goes thru the block doesnt it? To where when you pull the motor with no water pump, antifreeze goes thru the big holes and the bolt holes? If it's just antifreeze, put some silicone around the correct size bolt, then put 'er in.
Brandon
Crank is offline   Reply With Quote
Old 05-06-2004, 06:22 PM   #10
crazy longhorn
Fabricate till you "puke"
yup , those are the same holes used for the old style front eng mount brackets(tri 5 chevy v8's). a long time ago I helped a bud drop a 350 in his 57 belair, & one of the holes wasnt drilled from the factory.....long story short, i drilled a tad too deep, & green stuff started leaking. the dude almost cryed! I said, "aw hell, we will tap it & put a little dope on the bolt & screw it in". Formagasket aviation was the choice back then, & that booger never did leak. if you look at how many bolts go into waterjacket....you wont be scared crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-07-2004, 12:52 AM   #11
Hooter
My other Love
Hooter's Avatar
as I like to say "uh-oh silicone!" that stuff works in many situations, even to seal up some good cuts, plus it stay flexible on your skin there isnt huge amounts of psi when it comes to the antifreeze and chances are youll have antifreeze leak somewhere else before it leaks out of there, if the bolt is sealed
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
