05-06-2004, 10:55 AM | #1 |
one set closer
rust
my frame has some serious rust spot. can i just have the whole thing sandblasted and if so what kind of protection can i use to prevent any
furture rust. |
05-06-2004, 02:04 PM | #2 |
one set closer
someone please help me out here.
05-06-2004, 02:19 PM | #3 |
Blasting is a good idea, then use some special rust preventative paint (i.e. POR15, Rust Encapsulator) or you can opt to have someone prime and paint it with "industrial grade" paint, or you can use farm implement paint, or you could powdercoat it, or rattlecan Rustoleum, or prime and undercoat, or spray/roll on bedliner, etc. There are a lot of options.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
05-06-2004, 05:32 PM | #4 |
what ever coating you choose do it right away. The metal will flash oxidize pretty quick and you'll end up trapping moisture and rust underneath. After sandblasting the blaster should be ablt to treat the metal witha rust inhibitor.
1954 GMC 150 (for sale) 1970 GMC 1500 2004 Road King |
05-06-2004, 05:48 PM | #5 |
Is Primer needed before farm implement paint?
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
05-06-2004, 05:53 PM | #6 |
Almost done!
Dupont has a line of paint called: "Nason Automotive Finishes, Chassis Black" Part number 422-05. I was repainting the trailer for my fishing boat. It had some serious rust on it. I did not sand blast the trailer, it wasn't worth that much, I just used a wire cup on my grinder, then painted it. That was about 8 years ago and after hundreds of gravel roads and boat launches, it still looks great. It comes in a gallon can and it is pre thinned, but purchase some aeceton to clean up your paint gun. The paint did everything the guy at the paint store said it would. I think I bought it in Memphis on American Way. (Just moved to Dallas this year) Good luck!
The 1970 SWB Project Removed 6cyl manual trans, manual everything V8-350 Auto/PS/PDB Blazer Fuel Tank Behind the Marker Light Fuel Fill |
05-07-2004, 12:47 AM | #7 |
My other Love
how big is the hole, cuz just welding it shut could cause the frame to crack, it would be better to fishplate the whole area and make it stronget, but if it is a small hole then i wouldnt worry as much, if you blast all the rust out of it and dont drive it in the winter, and of course paint of over it, it should be just fine
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
