Old 05-06-2004, 05:17 PM   #1
hank
power brake conversion
i have a couple of questions about a power brake conversion. my 71 has front discs and manual brakes.
1) do i need a new porpotioning valve and master cylinder, or can i use the ones from my manual set up?
2) i just changed all of my brake lines, calipers and wheel cylinders during a brake change. will i need new ones for the power set up?
thanks for ya'lls help.
hank is offline   Reply With Quote
Old 05-06-2004, 06:50 PM   #2
neonlarry
neonlarry's Avatar
You can use the same master and p-valve. The rest of your brake stuff will be ok also. You should be able to get by bending (carefully) your lines to the master to move it forward a little to make room for the power booster.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-06-2004, 07:07 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Basicly, unbolt the master cylinder fron the firewall, and slip the booster inbetween.
Old 05-06-2004, 11:22 PM   #4
grayw0lf
Its pretty much a piece of cake. (Knock on wood.)
I just finished my power brake conversion less than an hour ago. Just make sure you get the power brake pushrod (from the pedal to teh booster). The hardest part was just bleeding the brakes, which is only b/c I'm slying solo.
Good Luck
John
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 05-07-2004, 12:59 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Good Luck
John
Don't even lossen any brake lines, just unbolt the master cylinder from the firewall with the lines still hooked to it. If you do it this way, there won't be any bleeding to do.
