05-06-2004, 10:55 PM | #1 |
New member. a couple questions...
Hey everyone...
I just bought a 1975 Cheyenne LWB. It was cheap but runs well and isn't in too bad of shape. Problem #1: The column(automatic) shifter has an amazing amount of slop in it. I can't always get Park and the other gears aren't easy either. I looked at the external linkage and it appears fine. Problem #2, which might be related. The TH350 seems to work well, and doesn't slip or leak. However, I can't get reverse going down with the shifter. I have to pass it, and get it coming up toward park, lol. The trans also occasionally shifts from 3rd to 2nd, on it's own, at part throttle. It shift down, shift up, shift down again, and so on. Everyonce in a while it will stay in second. The shifts are firm and the modulator and downshift cable are connected. The shifts come on time, both accelerating and slowing to a stop, so I wonder if it's mainly a linkage problem. Problem #3. The temp gauge, ammeter and fuel gauges are all inoperative. The oil pressure gauge works. When I switch the lights on the temp gauge goes to full hot. Any ideas before i dig into it? Thanks for the help!
1975 Cheyenne 350 2bbl, TH350, 3.42 rear. Rosewood/white insert |
05-07-2004, 08:21 AM | #2 |
been here longer than Liz
Welcome to the board!
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
05-07-2004, 08:24 AM | #3 |
Welcome from SW Washington State...
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
05-07-2004, 09:37 AM | #4 |
Welcome. As for question #3, it sounds like a ground problem in the cluster somwhere.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
05-07-2004, 09:55 AM | #5 |
Welcome to the board...... Looks like the guys already got your problems diagnosed. As you can see you will be in good hands with these guys helping you out. I know they helped me a bunch.
05-07-2004, 10:32 AM | #6 |
welcome, .......
the up shift, down shift, up shift..... could be part of a common problem, called wandering. as far as i know its just something that all th350s do. the "elders" will know more about that. |
