Hello
Has anyone have any diagrams for front or back or both air bag brackets for a 65 chevy , any help or suggestion to a place that can help me out would be great. Thanks ![]() |
Needs a Big Block
The back is super easy just take some 4.5 inch tubing cut it for your height, cap it off , to make a cup , I then driller a single hole in the middle cut the head off a 1/2 inch bolt slid it thru welded it into place so it was now a stud then I drilled my holes for the studs on the bags and for the air fitting to go thru , cut a notch in the side of the cup for my line to run thru , and bolted it in I drilled holes in my trailing arm for the bag to bolt thru the front im wirking on but its fairly simple just cap off the end of your crossmember where the spring used to go into , drill holes for your bage to bolt to and fitting to run thru and your set!
http://pic7.picturetrail.com/VOL212/...7/52371214.jpg
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
Thanks alot if you have any pointers on front thatd be great thanks
