Old 05-07-2004, 03:30 AM   #1
hank
where does ya'lls exhaust dump out?
going to the muffler shop this weekend and getting my exhaust redone. where do ya'll have yours dump out and why?
thanks.
hank is offline   Reply With Quote
Old 05-07-2004, 05:15 AM   #2
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Mine dump straight down just before the rear axle, I have 2 chamber Flow Masters with 3 inch tips. I have it that way cause it sounds better, much "throatier" than they were when they dumped out behind the rear wheels.
"The unexamined life is not worth living" -Socrates
'71 GMC Suburban 4x4
GMCjunkie is offline   Reply With Quote
Old 05-07-2004, 06:30 AM   #3
JimKshortstep4x4
Mine exit behind the rear wheels.
Jim
Old 05-07-2004, 06:32 AM   #4
71-longbed
Its Magically Delicious
71-longbed's Avatar
duals behind the rear wheels..
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 05-07-2004, 06:35 AM   #5
2low72
I agree with GMCJUNKIE. My exhaust setup is the same.
2low72 is offline   Reply With Quote
Old 05-07-2004, 06:44 AM   #6
Dean
Dean's Avatar
I have one that goes straight out the back below the rear bumper and one that dumps out below the rear quarter panel behind the wheel. I don't like the one that is straight out the back as well.
Plus don't make your pipes stick further out than your rear bumper and then back into something....
Dean is offline   Reply With Quote
Old 05-07-2004, 06:59 AM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Both mine exit behind the rear wheels. Also check your local inspection requirements, for ex. here in VA the exhaust has to exit 18" past the normally occupied area(cab), outside the frame rails or out the back, so a burb with turn downs wouldn't pass in VA(bet it sounds good though).
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-07-2004, 07:18 AM   #8
Pont
I need another Barley Pop
Pont's Avatar
same as GMCJunkie's
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 05-07-2004, 07:29 AM   #9
Lippyp
English Chevy Owner
Lippyp's Avatar
In front of the rear wheels either side, as fitted by previous owner. Would not be a good place on a 4x4 though as it would be too easy to crush the pipes against an obstacle.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 05-07-2004, 07:57 AM   #10
boraxman
Keepin an eye out
boraxman's Avatar
Behind rear wheels.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 05-07-2004, 09:28 AM   #11
crazy longhorn
Fabricate till you "puke"
mine is side exit , ahead of the rear wheels(Hooker headers.2 1/2" pipe,H pipe, running into Dynomax Superturbos. the tail pipes are a 90 (mandral bend) out of the muffs, the are bent 45 around the nose end of the leaf hangers, to kick out the sides at an angle. i like to hear them run, so side exit was my choice. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-07-2004, 12:14 PM   #12
lukecp
Formerly yellow72custom
lukecp's Avatar
My system looks just like Pont's, headers, 2.5" duals, and 40 series Delta Flow flowmasters with turndowns infront of the rear axle.
I like the way it sounds. Fairly quiet until you open it up and then it gets really loud. Has a fairly deep muscle car tone to it....kinda unique, sounds really good and turns heads.
For awhile i had the same system with no turndowns, and it sounded really deep and throaty. Turned even more heads, but was a little loud and kept getting me into trouble so i slapped some turndowns back on it. Quieted it down.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 05-07-2004, 12:26 PM   #13
demi
demi's Avatar
2.5 duals, crossover with 40 series flows exiting behind the rear wheels
demi is offline   Reply With Quote
Old 05-07-2004, 12:33 PM   #14
MeanGreenMachine
MeanGreenMachine's Avatar
I just had mine redone as the original had rusted a bit too much for my taste. 2.5" duals that turn out and dump just behind the rear wheels. I'm just a little disapointed with how far out the sides of the truck the pipes come. Gonna just cut them short and add tips that turn down.
MeanGreenMachine - 1972 Cheyenne Super 402
MeanGreenMachine is offline   Reply With Quote
Old 05-07-2004, 12:35 PM   #15
busterwivell
Guess I'm just different. Mine have Oval tips and exit just under the chrome rear bumper.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 05-07-2004, 01:00 PM   #16
4props
Mine exit out under the rear bumper no turn downs
1971 Cheyenne
4props is offline   Reply With Quote
Old 05-07-2004, 01:10 PM   #17
botboy
Exit behind the rear wheels ahead of the bumper at about a 45 deg angle to the wheels. Don't like the way it looks, something the PO did but other things are more important to fix right now than how aesthetically pleasing the exhaust exits are. Sounds pretty good tho.
botboy is offline   Reply With Quote
Old 05-07-2004, 01:16 PM   #18
k5hart
k5hart's Avatar
Hank - not trying to highjack your thread but I am looking at getting exhaust done on my blazer.
Does anyone have their exhaust dumping behind the rear wheels, but turned down towards the ground? I think Fast71 had a setup that I am referring too. Any pics?
Thanks, Jason
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 05-07-2004, 01:17 PM   #19
sactoC10
71 DELUX
sactoC10's Avatar
Red face
Mine exit just in front of the rear tires, but do not stick out in front of them. I'd prefer that they go straight out the rear, but I've not yet decided where I want the rear ride height to remain. It was easy to replace the rusted glass packs installed by the previous owner and simply turn the pipes out while I get the suspension and rear sway bar matters settled. :p
sactoC10 is offline   Reply With Quote
Old 05-07-2004, 01:53 PM   #20
MeanGreenMachine
This is what mine will look like once I get the tips put on this weekend. I'll try to remember to take pics.
Old 05-07-2004, 02:34 PM   #21
rambler
MOVE OVER
rambler's Avatar
Mine (single exhaust for now) once exited behind the left wheel, but I cut it short to make room for the overload springs when I put them on... havnet decided how to do it when I go to dual exhaust..
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 05-07-2004, 02:48 PM   #22
Dean
Dean's Avatar
Those turned down ones are cool until you get on a dusty road...... My Chevette has the chambered turned down duals and it will put up a cloud of dust. I'm running open headers at the moment though....problem solved....lol
Old 05-07-2004, 04:09 PM   #23
71Rat
ran out of money
71Rat's Avatar
i got hooker super comp headers going into purple hornies with the turn downs....... so mine exits before the door ends and it aimed twords the ground and out the the side..... more like a 45.... this is temp. but i still need to finish some work and get the engine started.... once i get some money i am going to run dual 2 chamber flows with an "H" or "X" pipe and have them dump just over the rear axle, but aimed a little to the side.
Rat
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 05-07-2004, 04:26 PM   #24
Zumo
Hot Rods For Life
Zumo's Avatar
The only way to go unles I get a setup like the Copper Head truck.
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 05-07-2004, 05:18 PM   #25
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Talking
My 67 Has Headers / H-pipe / Flowmasters / 4" X 12" Tips Dumping
45 Degrees In Front Of Rear Axle, Caution, I Changed This To Where
They Dump Under The Axle Now Due To The Fact I Was Trailering, I
Stopped At Good Old Wally World, Came Back Out To Find A Puddle
Under My Truck, Heated Rear End Oil/grease So Hot It Blew Out Of
The Overflow Hose, All Over My Flows And Underside Of My Truck,
Needless To Say It Was A Mess To Clean-up And For Some Reason
It Is Real Hard To Fill When Your In That Type Of Senario, My $.02
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
