Old 05-07-2004, 03:39 PM   #1
68 Suburban
68 Suburban's Avatar
Can Heat Affect a Coil?
Has anyone ever had a problem with a coil cut out when it gets hot and then works again when it is cool? Thanks
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-07-2004, 03:45 PM   #2
boraxman
Keepin an eye out
boraxman's Avatar
I doubt it. Coils are hard to kill. Speaking to a mechanic of 40 years he told me he has only seen 2 bad coils. I would also think when a electrical part goes its gone.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 05-07-2004, 04:08 PM   #3
crustysarge
Well, I once had a FIAT 131 that left me and my Italian girlfriend (now my wife) on the side of the road more than once. There was this one time outside of Munich Germany when we were on out way to Hahn Air Base and...well another time.
It was the coil and it was intermittent. Coils can and do go bad and heat is the big killer. That is why oil was/is used to cool them. They can cause all kinds of elusive electrical problems, i.e. you think it is everything else.
crustysarge is offline   Reply With Quote
Old 05-07-2004, 04:11 PM   #4
Sweet72
Sweet72's Avatar
The answer to your question is yes...
Transformers can and will break down under high temps (your ignition coil is a step-up transformer). I have experienced this with a few coils. Although I have not had one of the original oil filled coils as installed on our trucks go bad, I believe it's possible.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 05-07-2004, 04:19 PM   #5
boraxman
Keepin an eye out
boraxman's Avatar
Learn something new everyday
ZIP 91351
Old 05-07-2004, 04:44 PM   #6
Bowtie67
Bowtie67's Avatar
If you are running the stock coil it is possible, if you have an HEI the usual cuprit is in the module or pickup.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 05-07-2004, 06:02 PM   #7
73stepside
73stepside's Avatar
the 73 i had would stumble and stall when cold and when hot would work right. changed the coil and problem went away.
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 05-07-2004, 08:11 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I just went through the same problem on my yota it would work fine till the motor got warm and then it would kill the truck... Let it cool down and it would start agian...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-07-2004, 08:58 PM   #9
Gordo
Had very few coils go bad in my years, one in particular had a small hole chaffed in the base of it and the cooling oil inside drained out without noticing, causing it to heat up and quit, then worked again after it cooled. That was on a 1970ish Dodge van with the infamous slant six.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 05-07-2004, 09:50 PM   #10
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Had a coil pack go bad on a 88'grand am
sneakysnake is offline   Reply With Quote
Old 05-07-2004, 10:54 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've only been driving 15 years, and I've had about 4 or 5 coils go bad. Most all my cars have been old jalopies too...100,000 miles is when they become affordable. (my first car with less than 100 K on the clock was a parts car)
Chris, if you are running an HEI and having problems like you describe, you probably have a problem with the ignition module.
Funny thing with this is, everyone complains about the modules going bad, and some even carry a spare in the glove box, I've only had one go bad so far.
Only buy GM modules, the parts store over seas ones are not worth the box they are shipped in.
Old 05-08-2004, 02:28 AM   #12
RON WOODGEARD
Resident Young Old Dude !
From another backyard mechanic of 35 years,,,, Absolutely YES... When we had inferior coils in the 60's. ( technology hadn't caught up in that dept. yet) We used to mount our coils in the passenger compartment. They even sold a KIT to run it through the firewall. and the big old Accel, Supercoils had heat dissipating Ridges in them, because of the overheating possibility..
RON WOODGEARD is offline   Reply With Quote
