05-07-2004, 07:37 PM | #1 |
Grand PooBaa Member
Autometer Gauges
Does anybody have the instructions on installing aftermarket gauges in the stock dash and or the billet dash. Im getting a custom dash made but I need to know how to install the gauges.
05-07-2004, 07:42 PM | #2 |
PROJECT 7DEUCE
You may want to get ahold of mudder 67 he is pretty knowledgeable on that swap...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-07-2004, 08:43 PM | #3 |
I just installed a full set in my custom dash, They are relatively pretty easy, there are directions that come in each of the guages as well as a new oil sending unit and water temp guage. I had installed a Painless wiring which had all the wires marked to where they go, another helpful thing is purchasing the guage wiring setup kit from painless, It allows you to put your dash assembly together outside of the cab and just plug it in when your done with all the wiring. Hope this helps...
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
05-07-2004, 09:55 PM | #4 |
They are really easy to mount and wire up, one of the simplest jobs I have done on my truck, you just have to have patience and do a good job running all the wires otherwise you will be pulling the whole thing out again. They come with their own mounting bracket, and everything you need. They come with the necessary hardware too, like oil pressure lines etc. The stock bezel itself needs a little work that is simple to do too with a dremel or equivalent.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
05-07-2004, 10:23 PM | #5 |
FUEL CELL GURU
Like these???
05-07-2004, 10:54 PM | #6 |
PROJECT 7DEUCE
Damn what do all those guage's read????? And what are all the togle's for????
05-07-2004, 11:08 PM | #7 |
FUEL CELL GURU
The reason the dash bezel looks overwhelming is the 5 air pressure gauges. One for each bag and one for the tank. The switches are two-way momentary switches are for the air ride. Typical 10-switch setup. Later, FCG
05-08-2004, 02:36 AM | #8 |
I can maybe help ya with the wiring if they are electric guages. Its all pretty easy. PM me if ya want me to explain it.
05-08-2004, 08:29 AM | #9 | |
PM'd you for help on this.... Thanks...
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
05-08-2004, 08:55 AM | #10 |
Will get back with you later today or this evening. Getting company here in a bit.
05-08-2004, 08:21 PM | #11 |
Grand PooBaa Member
Okay Fuel Cel Guy has posted just about what im looking for.
Here's the thing, im having a dash made, but its not out of metal. It starts out as (get this) a paste. My old job is using it for aerospace and a place out her called So Cal Speed Shop is getting some things done. Any way what I need to see is the back of a dash to see how they are mounted. If I need to place set screws on my new dash. The dash can be anodize any color. Once its finished I will attempt to post a picture. Thanks. |
05-17-2004, 03:16 PM | #12 |
Nothing clever
did we ever get information we can share out of this??
I am looking to do this as well, but wanted to see how involved first. Also Anyone know if I can replace one at a time, my speedo is broke and I wanted to replaceit first as I save for the rest.
Got "the Midas Touch!" |
08-04-2004, 07:19 PM | #13 |
Where to buy???
Where are you guys buying your dashes from?
I want to run two 5" and five 2 5/8" |
08-05-2004, 08:50 PM | #14 | |
http://www.jjengineering.us/products/products.htm
08-05-2004, 10:09 PM | #15 |
Im about to order 7 gauge set up from autometer speedo,tac,oil pressure,water temp
vac,fuel gauge and volt meter. Which is easiest to hookup for each one electric or mechanical?
bogey5 |
