Old 05-08-2004, 12:08 AM   #1
NPilot1975
NPilot1975's Avatar
Front Crossmember?
Are all of the front crossmembers from 67-87 the same? I understand that they bolt in the same way, but are the suspension components actually the same? Could I take a 67 crossmember and bolt on 72 A-arms and spindles to have disc brakes? Thanx for any help you can give me.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 05-08-2004, 01:04 AM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Yes you can. That's what I did with my 68. You will want to use the 72 tie rod ends too I believe. The donor 72 I got my parts off of had recently had all new tie rod ends and an idler arm, so I took everything off of it and put on mine.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 05-08-2004, 02:51 AM   #3
NPilot1975
NPilot1975's Avatar
Is the frame the same for all 67-72 chevy's. I have a shortened LWB frame and am planning on getting an actual SWB. I want to be able to use all my parts like, power-steering brakes, rearend, etc. Thanx for your help.
Old 05-08-2004, 10:09 AM   #4
glock35ipsc
The only thing I can think of is that a 67 frame will not have the "dimple" in the frame rail to accomidate a power steering gear box. The gear is larger (wider) on the power steering gear box, thus needing the frame to be pushed in a little for it to bolt up tight. Other than that, as long as it is a coil spring truck, it should be identical.
Someone else please pop in if I am wrong.
Bob
Old 05-08-2004, 10:40 AM   #5
68C15
blood type; Retumbo
68C15's Avatar
same frame?
the frames from 68-72 are the same. I changed my leaf spring 68 GMC to coil typr rear suspension by just removing all rear suspension components from a 72 Chevy & it bolted up to my frame with only drilling the holes for the upper coil mount brackets in my frame, otherwise everything went right in all most by itself. at the same time I installed bags in place of the coils.
68C15 is offline   Reply With Quote
Old 05-08-2004, 10:41 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
i also trans planted a front suspension from a 80 C10. instant disc brakes
Old 05-09-2004, 12:02 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The other difference on the 67 frame verses the 68 - 72 is provisions for a big block. On the passenger side, in front of the engine is a curled up section...that is missing on the 67 frame.
