05-08-2004, 10:54 AM | #1 |
1972 4 core A/C radiator core support near mint
This is an original near mint Core support for an A/C 4 core.
The only rust I found was in the little bracket that the rubber sits in underneath the radiator. you should be able to see it in the picutres.. Other than that this is almost perfect.. I haven't measured it yet but it weighs 40lbs and you can see it would be considered oversized.. I would ship it UPS.. from 99223 I'm asking 175.00 plus S&H
Support The Board |
05-08-2004, 10:25 PM | #2 |
WHAT IS THE DIFFERENCE BETWEEN SAY A 2 ....3.... & A 4 CORE RADIATOR CORE SUPPORT??. DID G.M. ACTUALLY MAKE DIFFERENT RADIATOR SUPPORTS FOR DIFFERENT THICKNESS RADIATORS? OR ARE YOU JUST PULLIN MY LEG???. I WAS UNDER THE IMPRESSION THAT G.M. ONLY USED DIFFERENT WIDTH RADIATOR HOLD DOWNS FOR DIFFERENT THICKNESS RADIATORS. HMMMMM ...... I'M NEVER TOO OLD TO LEARN SOMETHING NEW. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
05-08-2004, 11:00 PM | #3 |
Hope not, I just got a 4 core radiator and had to get the 4 core supports and brackets. If I have to, I will modify my support to make it work.
72 Chevy C20, SOLD (Dang it.) 09 Challanger RT six speed in all black. 74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power. 73 C10 long bed, 350/350 combo, nice shape. |
05-09-2004, 11:53 AM | #4 |
I'M SURE THEY ARE ALL THE SAME WITH THE EXCEPTION OF A/C RAD. SUPPORTS, WITCH HAVE A HOLE FOR THE A/C LINES & A BRACKET TO HOLD THE LINES TO THE BOTTOM OF THE BATTERY BOX. JOHN
05-09-2004, 04:41 PM | #5 |
I don't think there is a difference
I just put up for sale as to what came out of it..If it had been a 3 core I would have put that in the title also.. And this does have the hole for the A/C I do know this one of the best looking supports I have seen other than restored or bought new..This one is original GM..
Support The Board |
05-11-2004, 04:05 AM | #6 |
last try
Support The Board |
05-20-2004, 01:30 PM | #7 |
FixerUpper
I really like the support
BUt its a little steap for plus the ride , you need anything i have a parts truck well what left anyways let me know maybe we can work something .
1-Cheyenne 72 700R4,camper special all original when i got it then i improved it a little Blue and White 3.73,4 core rad, 700r4,MSD hei ,turbo muffs dual exhaust only had 50 k on it when i bought original mile sweet old ladies truck turned into a stump puller No. 2 C-10 72 w/air and Tilt and power and the cheyenne trim package shtbd is dropped 2-3w/factory tilt has torq thrust 2 rims 2003 dodge neon steel blue color |
05-26-2004, 08:32 PM | #8 |
Last try before Ebay..
TTT
Support The Board |
