Old 05-08-2004, 03:43 PM   #1
gmc71
gmc71's Avatar
Ford Front axle Question
My uncle had a front axle out of a 78 3/4 ton Ford, it has discs on it and 10 bolts on the cover, is this also a Dana axle. Can it be transplanted into my truck so i can have discs up front? The price is right(free) so I thought it would be worth asking.
He also has an NP205 from out of the same truck, should I get if for a spare, I assume is would be the same?
gmc71 is offline   Reply With Quote
Old 05-08-2004, 06:16 PM   #2
IoWnZa
Big Block Blazer
What year is your Truck?
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys]
IoWnZa is offline   Reply With Quote
Old 05-08-2004, 06:51 PM   #3
ryanroo
ryanroo's Avatar
if you are planning on putting it in a GM 4x4 you can do it, but the t-case drop is on the wrong side, so you would have to use a ford case. i don't know how well you could pair a GM tranny and FMC tcase as the mounting patterns are different. i am pretty sure the spring centers are either the same or so close it wouldn't matter, but you may have to use for spring plates and u-bolts. if this is goin in a ford vehicle it will fit in another 3/4 ton of the same vintage, but i think that the 1/2 ton trucks used coil/radius arms.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-08-2004, 11:59 PM   #4
gmc71
gmc71's Avatar
-To Clarify- I was hoping to put this into a 67 3/4 ton chevy K20 I am getting, and want dics brakes on.
Old 05-09-2004, 07:20 AM   #5
Blazer1970
Blazer1970's Avatar
You need to find a newer GM axle for your K20. As noted above, the Ford axle has the differential on the wrong side. Any 3/4 or SRW 1 ton axle from '72 - '87 will work.
Blazer1970 is offline   Reply With Quote
Old 05-09-2004, 07:54 PM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Side note: if it's a dana60 high pinion, then someone doing a IFS to solid axle swap would probably pay plenty for it, as the 87(92) up IFS chevys have the pumpkin on the driverside.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-09-2004, 08:10 PM   #7
drink2mny
drink2mny's Avatar
Yup Ford pinion on wrong side to use with your chevy driveline (transfercase)..
You could swap over ford stuff but that would cost you more than finding a 3/4ton dana 44 out of a '73 up chevy..
if its free, then I would take it and re sell it to get money for a proper frontend to put in.
And no, the 205 out of that truck would be a ford 205 which means it would match to the pinion on the frontend( driverside output to the driverside pinion..)Way to much of a hassle to swap over..I knoe free sounds good but pain in the a$$ swap overs don't..
Take the stuff and sell them in a newspaper or internet...
then buy the right stuff to put in..
Just my .02
Support The Board
drink2mny is offline   Reply With Quote
Old 05-09-2004, 09:37 PM   #8
1FaastC10
1FaastC10's Avatar
too bad you're so far away, i've got a 3/4 4x4 front axle that i need to get rid of. it came out of a '79 K20.
1FaastC10 is offline   Reply With Quote
Old 05-09-2004, 11:23 PM   #9
gmc71
gmc71's Avatar
Thats always the way!!!
If anyone is interested in the parts let me know.
Old 05-10-2004, 02:20 PM   #10
1969 GMC
1969 GMC's Avatar
Thumbs up
ford axles of that vintage are sought after, like Jim said people doing SAS (solid axle swaps) want them, and also Jeeps have driver's drop differentials.
If you can, post pics of the axle...Ford high pinion dana 60's aren't as easy to ID as GM/Dodge dana 60s, because they use 4 ubolts vs 3 on a GM/Dodge, so from far away they will look like dana 44's.
However, you can look to see if it has kingpins (dana 60) or balljoints (dana 44). Also, it will have the model # cast into the housing, but this may be unreadable.
fyi, if it does happen to be a HP dana 60 and it is in good shape, you can expect to get $1200 or so for it, if you decide to sell. hope this helps
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
