Old 05-09-2004, 06:18 PM   #1
1FaastC10
1FaastC10's Avatar
1 ton
went yesterday and picked up my K30 dually. i'm going to be putting the front axle, and gears out of the rear axle under my C/K10 project. i'd say i got a pretty decent deal. $800 for the whole truck. body is rough, and will most likely be totally scrapped except for the hood. it came with 2 SM 465s and 2 NP205s, too, so i might be able to sell them and get some of my money back.
1FaastC10 is offline   Reply With Quote
Old 05-09-2004, 07:20 PM   #2
IoWnZa
Big Block Blazer
good deal.
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys]
IoWnZa is offline   Reply With Quote
Old 05-10-2004, 12:14 AM   #3
1969 GMC
1969 GMC's Avatar
add the $300 or so for the SRW hub bodies, and its still a deal
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-10-2004, 10:54 AM   #4
LONGHAIR
Dually axles are wider than standard............as long as you are aware of that and the potential wheel choices..........
LONGHAIR is offline   Reply With Quote
Old 05-10-2004, 01:10 PM   #5
1969 GMC
1969 GMC's Avatar
Thumbs up
That's what I was referring to with the "SRW Hub Bodies."
If you remove the DRW hub bodies and bolt on some SRW versions, the axle will be the same width (69" WMS-WMS) as a normal SRW axle. This is the only huge difference in GM dana 60's that I am aware of.
However, SRW hub bodies are one of those highly coveted parts that wont be cheap. GM sells them new for around $190-200 a pop. You can also buy aftermarket for around the same price.
1969 GMC K2500
1996 Honda Accord
Old 05-10-2004, 01:22 PM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Or you can get hummer rims and keep the dually hubs.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-10-2004, 07:10 PM   #7
1FaastC10
1FaastC10's Avatar
which is what a lot of rock crawlers do. i dont think im going to go that route, as i dont like the idea of a 16.5" rim, beadlock or no beadlock. sidewall flex is your friend, no use killing it with a 16.5" rim when a 15" rim is easily adapted.
Old 05-10-2004, 07:37 PM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I hear you. The 16.5" rims on my Chevy are alot stiffer then the 15" tires on my GMC. Both BFGs (well the mud(16.5) and ATs(15)).
