Door Hinge RUST
how do you fix upper door where hinge is mounted. hinge is bolted on tight but ripping inside of door shell out.
its all about the +6 inches
Welcome to the board lamar.
You describe a common problem in my part of the US...but i wouldn't expect it in your neck of the woods. You could either cut out the cancer, and repair it, or get a new door. Even if you were to get a new door, it may be a good idea to re-enforce the area, they are prone to ripping there. |
My other Love
I have the same problem but instead of rust it is all stress cracked around the hinge on the door, gotta fix that one day or else the door might fall off
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
I had the same problem with the passenger door when I first got my truck. You should be happy the problem is on the door and not surrounding the hinge mount on the post.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
This is generally caused by the hinge..........well not exactly the hinge, more like the lack of lubrication on the hinge. It comes from the wind-check sticking. The hinge wants to stay open and someone forces it shut, all of the pressure is on a very small area of the door shell. There is nothing wrong with reinforcing the area......but it's not reaaly that the door is weak. Maintainence of the hinges (pins bushings and wind-check) is the key.
Thanks guys you made me feel better knowing it is a common problem. Love this message board and how everyone helps and shares their knowledge.
#7 | |
