Old 05-10-2004, 12:41 PM   #1
Trucks
Is that a Chevy 69...?
tire rubs steering arm
My 68 GMC 4x4 has what amounts to maybe a 1-2" lift becuase of adding leafs to old ones, a shop did this. But the tires I got at a real good price with rims are BIG, and I like that it makes up for the SM465 trans and 4.56 gears. However the left tire hits a steering arm when I turn to the right. Has anyone fixed this before? All I can think of is
1. smaller tires
2. alot more lift
3. customize the steering arm
4. weld a nice flat peice of metel around the arm so the smooth part of the tire hits it instead of the tread grabbing that steering rod.
OH, I didn't mention I have no power steering, which I'd like to have but have no clue how or how much $. The tires are about 33" currently.
I should also mention that the previous owner put in a 250-6 which I am debating on swapping to a 350 on a limited budget.
Ahhhh, the wonderful sound of a rumbling V8.
Trucks is offline   Reply With Quote
Old 05-10-2004, 11:23 PM   #2
Budweis
Geared for Collision
Budweis's Avatar
i definitely wouldnt do number 4 lol, id either get smaller tires or get a 4" lift, you can get a block lift for the rear kit for pretty cheap.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB
1970 C/K20 3/4 Ton
1996 Collectors Edition Corvette
1977 Corvette Coupe
Budweis is offline   Reply With Quote
Old 05-11-2004, 12:11 AM   #3
ryanroo
ryanroo's Avatar
im unfamiliar with the manual steering, but it coudl be the backspacing of your wheels, or the width of tire and/or wheels. my truck has a 2 inch lift and 33-12.50/15 on rally wheels and i don't have the problem, but again its power steering, so i don't know
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-12-2004, 11:17 AM   #4
Trucks
Ya it actually hits a nut with a pin thru it which holds the arms together, but even with 2" smaller tires I would hit the arm next to it. I'll have to see if I can get a pic. ANyone else have manual steering? I have manual brakes too.
Old 05-14-2004, 01:05 AM   #5
1FaastC10
1FaastC10's Avatar
wheels with less backspacing will fix it.
1FaastC10 is offline   Reply With Quote
Old 05-14-2004, 07:39 PM   #6
Trucks
extensions?
Do they make extensions for these 8 bolt wheels, I can't find any used "deep" wheels 16" 8 lug. Anyone have some for sale?
