Old 05-10-2004, 01:29 PM   #1
67chevemall
67chevemall's Avatar
Question What holds the door opening rod on???
The rod that goes from the door handle to the jamb latch has come off!
I looked all around the bottom of the door for a clip or something but no luck!
What kind of clip holds the rod onto the latch on the 1967 trucks?
The rod has a 45 deg. bend where it goes into the latch but I can't find what holds it altogether!
I keep getting locked out! Ahhhhhhhhh!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 05-10-2004, 02:10 PM   #2
1969 GMC
1969 GMC's Avatar
iirc, there is afunky little metal clip that does the job, sounds like yours fell into the door. I'd check the bottom again, I had to use a magnetic wand to get all the tiny pieces that fell down in there when mine decided to fall apart on me.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-10-2004, 04:26 PM   #3
junkyardjohn
junkyardjohn's Avatar
THIS IS A PICTURE OF THE LITTLE CLIPS. THEY SHOULD BE AVAILABLE AT YOUR LOCAL AUTO PAINT SUPPLIER. (THATS WHERE THEYRE AVAIALABLE HERE) THEYRE COMMONLY REFERED TO AS "JESUS CLIPS" CAUSE WHEN YOU UNLATCH THEM & THEY GO FLYING ACROSS THE GARAGE, IT'S COMMON FOR YOU TO HEAR "JESUS... WHERE DID THAT CLIP GO??" JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 05-10-2004, 07:07 PM   #4
Sweet72
Sweet72's Avatar
Never heard them called Jesus clips before. A little aircraft trivia though... The nut that holds the main rotor on a helicopter is sometimes called the "Jesus nut". I'm sure you can guess why.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 05-11-2004, 09:37 AM   #5
67chevemall
Thanks Guys!
Old 05-11-2004, 09:37 PM   #6
walker
walker's Avatar
You can get those little clips at AZ, checker, Napa and the likes. They are in the help section, or the carb parts section.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 05-11-2004, 09:54 PM   #7
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
aren't those also used on the rod style throtle linkage on our trucks?
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 05-12-2004, 02:54 AM   #8
jimfulco
Same basic deal. Be sure of which direction the clip part goes before you buy.
jimfulco is offline   Reply With Quote
Old 05-12-2004, 08:46 AM   #9
67chevemall
Thanks again!
The problem is the chop
It makes the window track to close to the pin which pops it off!
I drilled a small hole in the rod and used a different clip!
Works great now!
Engineering baby!
Old 08-03-2004, 10:45 AM   #10
71-longbed
Its Magically Delicious
71-longbed's Avatar
are the same "jesus" clips uses for all the rods in the doors ... or are the orientations different on some ??
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 08-03-2004, 10:53 AM   #11
67chevemall
I would say they are the same up until a certain year!
67-72 would be the same!
