Old 05-10-2004, 07:11 PM   #1
atcavage
High oil pressure
I have high oil pressure, like the fourth quarter of the gague when I'm driving. When idelling, it is just past the center of the gague. At 60+, it goes WAY off the marked section. What should I do besides change the oil? And what kind of oil do you recommend?
1972 1/2 ton Chevy C10 V-8 350, crate engine, with Flomaster dual exhaust. She's Old Blue the Truckinator (no relation to Arnold )
atcavage is offline   Reply With Quote
Old 05-10-2004, 07:17 PM   #2
dion
72 Cheyenne
dion's Avatar
Is this with the engine hot or cold? If cold then it's normal, mine used to do that also.
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 05-10-2004, 08:05 PM   #3
canadianchevy72
Did you rebuild the motor with a high volume oil pump lately? That could be it.
1972 Chevy C/10
350/200r4
canadianchevy72 is offline   Reply With Quote
Old 05-10-2004, 11:24 PM   #4
atcavage
This is warm. I'm usually on the freeway at between 60-75mph. I got a crate 350 dropped in in October and the oil was changed about 500 miles ago, so it beats me. Before on the last engine, it ran no more than half when everything was okay.
Old 05-11-2004, 01:46 AM   #5
Bowed
double check your pressure at the block with another gauge .
Bowed is offline   Reply With Quote
Old 05-11-2004, 07:15 AM   #6
krazy_texan
krazy_texan's Avatar
sounds normal to me if you have an aftermarket or modified motor
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 05-11-2004, 08:12 AM   #7
smokekiki
Mike
smokekiki's Avatar
When I rebuilt my 402,I used a high volume pump.It kept the gauge pegged all the time.I bought a NOS GM 80lb gauge off e-bay.Now the needle reads in the upper part of the gauge.If you take Your instrument cluster out,the gauge has a pressure reading on it.My old one was a 60lb.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 05-11-2004, 10:26 AM   #8
dion
72 Cheyenne
dion's Avatar
sounds normal to me too but if you're worried about it try a lighter weight oil, maybe that will help.
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 05-11-2004, 10:38 AM   #9
StingRay
StingRay's Avatar
Peggin the needle is normal for a performance oil pump on a 60 psi gauge. I have a high volume pump and I also have an 80 psi gauge in my cluster. They are easy to find in the big trucks.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 05-11-2004, 02:01 PM   #10
atcavage
Thanks guys, I guess I was just being paranoid. I looked everything over, and the whole thing is fine. Turns out that the gagues all have a tendency to be inaccurate. My Tach is so bad, I don't have one!
