Old 05-10-2004, 11:40 PM   #1
BaggedC10
Under construction!
BaggedC10's Avatar
Which oil pan?
Who offers the best aftermarket oil pan for these trucks? Maybe one that is low-profile too.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 05-10-2004, 11:46 PM   #2
BaggedC10
Under construction!
BaggedC10's Avatar
Any thoughts on this one?
If your oil pan has been taking some abuse, fight back with an additional 3/16'' steel armor plate on the bottom of this innovative oil pan. Save your engine while protecting it from perforation or abrasion damage. Chrome finish.
Old 05-11-2004, 02:25 AM   #3
TIMSPEED
TIMSPEED's Avatar
I would use a Milodon. I've seen one that's low profile, and looks killer.
Low Profile Oil Pan
Kinda Pricey...but it's only 8¼" Deep.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 05-11-2004, 10:50 AM   #4
BaggedC10
Under construction!
BaggedC10's Avatar
Thanks for the link, Tim. That is exactly what I'm looking for.
Old 05-11-2004, 12:43 PM   #5
swervin ervin
You get what you pay for
swervin ervin's Avatar
Here's the one I have.
Oil Pan
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 05-11-2004, 12:45 PM   #6
swervin ervin
Oops. I just now seen you have a 87. This number doesn't fit one piece rear seal engines. I'll see if I can find the right number.
Old 05-11-2004, 12:52 PM   #7
swervin ervin
Here you go. The link says it's a 6 quart pan, but my Moroso catalog says it's a 7 quart pan, just like my 20200.
Old 05-11-2004, 02:13 PM   #8
low 84
low 84's Avatar
make sure you get your pick up set at the right height for the pan you get. if you go to a shallower pan your stock pick up won't work
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 05-11-2004, 05:48 PM   #9
BaggedC10
Under construction!
BaggedC10's Avatar
Thanks for the link(s), Mike. I think I'll go for the Moroso oil pan---Good price and I'm sure the quality is top notch.
Old 05-11-2004, 06:09 PM   #10
ocbaud
Garage Queen Material
i have the same pan mike has, and it is of great quality. make sure you get the right oil pickup though.
ocbaud is offline   Reply With Quote
Old 05-12-2004, 12:56 AM   #11
raceman6135
Dino burner
raceman6135's Avatar
I'd second the motion on a Moroso pan. Their quality is great; I've seen two Milodon pans crack on drag race engines (one on a 351C Ford, the other on a blown alcohol Big Block Chevrolet), so I'm not very impressed with them at this time.
If you're going to swap pans, and if this engine is "built" at all, also consider a crank scraper and a windage tray. And if the engine is REALLY built and you'll be abusing the truck (drag, solo, etc. racing), a pan with trap doors is a worthwhile investment.
DJS
raceman6135 is offline   Reply With Quote
