It's a catastrophic success.
![]() Join Date: Jan 2003
Things to check, rubber boot, vented cap, leaking sending unit,and in the later models had a in cab vent in the passenger rear cab post
I got rid of the gas smell when I went to the Blazer tank under the bed.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
![]() Join Date: May 2002
Are you talking about a raw gas smell or a partially burned gas smell? (Like with a stuck choke).
Stepsides look like real trucks! Smitty ![]() |
More or less raw gas smell, I had been thinking it was something maybe to due with the tank inside of the truck.
I had a similar problem that went away when I replaced the fuel sending unit's gasket.
Mike 67' GMC Fleetside |
![]() Join Date: Dec 2003
I had that same problem and come to find out my gas cap was bad and everytime i turned right a little gas would spash out......that was my smell....
https://www.ebay.com/itm/295742064443 |
Worst culprit seems to be that gas cap. Especially if it gets better with windows up. I'm told it was a "design flaw". Best cure- move that gas on back!
get rid of the tank you won't regret it!
1971 Chevy Cheyenne 383/350 LWB 2wd Built to use, and look good. ![]() |
Just buy a new cap(vented for the earlier years), neck grommet, and sending unit gasket. That covers everything except bad solder joint on the neck (which is somewhat prone to leakage, but repairable). To check the neck joint, run your tank low on gas, seal up the top with duct tape, pinch off the rubber fuel line at the pump(if that worries you, I didn't), let her sit in the sun for a little while, then use soapy water, around the neck and look for bubbles.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
Southern Bowties
Also-check/replace the rubber fuel lines from the tank to the hard lines.
1972 Cheyenne 350/350 |
What's the best way to go? Poly, Alum. or orginal blazer tank out of 69-72 blazer.
#13 |
More Cowbell....
Just don't go Poly. They change shape, expand, contract, etc...
Use a METAL TANK! ![]()
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
#14 |
Fuel cell with safety foam. If mine ever goes bad I may get a fuel cell that holds 30 gallons if it will fit somewhere on the truck.
72 Chevy C20, SOLD (Dang it.) 09 Challanger RT six speed in all black. 74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power. 73 C10 long bed, 350/350 combo, nice shape. |
#15 |
![]() Join Date: Sep 2001
I just replaced the rubber gasket for the sending unit when I smelled of gas - fixed it right up and I found my thinking to be much more clear headed when I was breathing pure oxygen instead of a rich mix. Cost $2 and 10 minutes. I will eventually move the tank out but a $2 quick fix is so easy!!
