Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Old 05-11-2004, 02:06 PM   #1
baxie
miss in number 7
i am new to this site and i am needing some help i just got back from Iraq about 2 weeks ago and my 1996 chevy truck with a 305 vortec has a miss in #7 i have had the check engine light coming on so i had it scaned i put new plugs, wires, cap and rotor on it i have 120 psi of compression in #7 the rest are about the same too the plug comes out with a lot of carbon built up on it it smothes out a little bit at a hirer rpm but on the low side it is very bad any help would be great
baxie is offline   Reply With Quote
Old 09-29-2004, 04:26 AM   #2
victoryauto
If it is a constant miss on number seven it is possibly the holograph in the distributor that is bad or crankshaft position sensor. If it only does it when it is cold, it is more than likely going to be the coolant temp. sensor in the front of the intake. Hope this may help you out.
victoryauto is offline   Reply With Quote
Old 09-29-2004, 09:41 PM   #3
Steveo_supremo
Steveo_supremo's Avatar
Also very possibly could be a bad injector. Best way to tell is have an injector balance test done at a dealership or qualified shop.
89 GMC K1500 ECSB, 94 Chevy C1500 ECSB
Steveo_supremo is offline   Reply With Quote
Old 09-30-2004, 09:32 PM   #4
oldyeller
Captain CAAAVVVMMMAAANNN!
oldyeller's Avatar
not to highjack your thread,
but I am having the same problem but on cyl 1 and 3. its very intermintant. have ruled out the ignition system, and think its the injectors, but what if it only does it when its warm? could it still be the temp sendor? and whats that injector balance test run $ wise?? oh, and is the holograph and crank sensor test-able??
72 LWB Fleetside C10 Custom 350/350
97 GMC Yukon 4X4 SLT
Anna, Texas
check out the project old yeller
oldyeller is offline   Reply With Quote
Old 10-13-2004, 02:34 AM   #5
victoryauto
That was a misprint on my part about the coolant temp sensor. If the engine runs bad AFTER warmup then the coolant temp sensor could be bad. Sorry about the misprint.
